Welder
11 Jul 2010 19:48 #381813 by Darkangel
Welder was created by Darkangel
Ok all i have is a stick welder....I know that most body work is performed using a tig or a mig welder. I would like to make some frame modifications to my motorcycle, can i use my stick at a low amperage and do these mods or am I stuck with buying a new welder?
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
11 Jul 2010 20:05 #381825 by PLUMMEN
Replied by PLUMMEN on topic Welder
you can stick weld it,practice on some old pipe first though
11 Jul 2010 20:28 #381840 by Darkangel
Replied by Darkangel on topic Welder
what size and type of rod should I use just to be safe?
11 Jul 2010 20:50 #381852 by PLUMMEN
what kind of welder do you have and how good are you with it?im a fan of 7018 rod myself,but i use a dc welder for stick welding which is easier for me
11 Jul 2010 20:53 #381859 by PLUMMEN
11 Jul 2010 20:53 #381861 by Darkangel
well i used to rebuild trailer both steel and alum. bull trailers with a mig, the other trailers I used a stick...so i am pretty good with them.
11 Jul 2010 20:57 #381863 by PLUMMEN
cattle are tough on equipment :laugh:
11 Jul 2010 20:59 #381864 by loudhvx
Replied by loudhvx on topic Welder
Don't get 6013 rod. I just went through about a dozen rods of it and now I want to stab myself in the neck. Total butcher job, especially welding stainless with plain steel, oh and did i mention the metal had paint on it too... :angry:
Sorry, just had to vent.
11 Jul 2010 21:49 #381874 by PLUMMEN
we used to use a rod called 308-16 i believe it was called for welding stainless back when i used to wire packing plants,beautifull welds with it.
i always considered 6013 to be good for welding stuff that was going to be covered with mud! :laugh:
11 Jul 2010 23:06 #381892 by Darkangel
lol yeah you use 6013 in oil apps and stuff...or on the side of a naval vessel....lol not on anything you want seen and admire by the public.
Take a look at this though I am thinking about getting on of these. www.cut-like-plasma.com/info_henrob_torch_kits.htm
12 Jul 2010 04:51 - 12 Jul 2010 05:35 #381906 by PLUMMEN
i bet you could pick up a decent used miller or hobart wire welder for the same price as that torch kit,craigslist is full of stuff these days B) omaha.craigslist.org/tls/1836064610.html
Last edit: 12 Jul 2010 05:35 by PLUMMEN.
12 Jul 2010 06:15 #381921 by Old Man Rock
Replied by Old Man Rock on topic Welder
Heli-Arc (Stick welding) is fine if accomplished correctly... Hell it will provide pretty much the desired tensile strengths (pull apart resistance) for welding.... Actually stronger then TIG...
NO... do NOT lower your amperage (within limits of course) for the rod size... Instead use a smaller size low hydrogen 7018 for example gauge rod on appropriate current settings for smooth, non slagged/porosity welds.
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
