Welder
- Darkangel
Welder
11 Jul 2010 19:48
Ok all i have is a stick welder....I know that most body work is performed using a tig or a mig welder. I would like to make some frame modifications to my motorcycle, can i use my stick at a low amperage and do these mods or am I stuck with buying a new welder?
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
- PLUMMEN
Re: Welder
11 Jul 2010 20:05
you can stick weld it,practice on some old pipe first though
- Darkangel
Re: Welder
11 Jul 2010 20:28
what size and type of rod should I use just to be safe?
- PLUMMEN
Re: Welder
11 Jul 2010 20:50
what kind of welder do you have and how good are you with it?im a fan of 7018 rod myself,but i use a dc welder for stick welding which is easier for me
- PLUMMEN
- Darkangel
Re: Welder
11 Jul 2010 20:53
well i used to rebuild trailer both steel and alum. bull trailers with a mig, the other trailers I used a stick...so i am pretty good with them.
- PLUMMEN
Re: Welder
11 Jul 2010 20:57
cattle are tough on equipment :laugh:
- loudhvx
Re: Welder
11 Jul 2010 20:59
Don't get 6013 rod. I just went through about a dozen rods of it and now I want to stab myself in the neck. Total butcher job, especially welding stainless with plain steel, oh and did i mention the metal had paint on it too...
Sorry, just had to vent.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- PLUMMEN
Re: Welder
11 Jul 2010 21:49
loudhvx wrote:
i always considered 6013 to be good for welding stuff that was going to be covered with mud! :laugh:
we used to use a rod called 308-16 i believe it was called for welding stainless back when i used to wire packing plants,beautifull welds with it.Don't get 6013 rod. I just went through about a dozen rods of it and now I want to stab myself in the neck. Total butcher job, especially welding stainless with plain steel, oh and did i mention the metal had paint on it too...
- Darkangel
Re: Welder
11 Jul 2010 23:06
lol yeah you use 6013 in oil apps and stuff...or on the side of a naval vessel....lol not on anything you want seen and admire by the public.
Take a look at this though I am thinking about getting on of these. www.cut-like-plasma.com/info_henrob_torch_kits.htm
- PLUMMEN
Re: Welder
12 Jul 2010 04:51 - 12 Jul 2010 05:35
Darkangel wrote:
omaha.craigslist.org/tls/1836064610.html
i bet you could pick up a decent used miller or hobart wire welder for the same price as that torch kit,craigslist is full of stuff these dayslol yeah you use 6013 in oil apps and stuff...or on the side of a naval vessel....lol not on anything you want seen and admire by the public.
Last edit: 12 Jul 2010 05:35 by PLUMMEN.
- Old Man Rock
Re: Welder
12 Jul 2010 06:15
Heli-Arc (Stick welding) is fine if accomplished correctly... Hell it will provide pretty much the desired tensile strengths (pull apart resistance) for welding.... Actually stronger then TIG...
NO... do NOT lower your amperage (within limits of course) for the rod size... Instead use a smaller size low hydrogen 7018 for example gauge rod on appropriate current settings for smooth, non slagged/porosity welds.
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
