t-dubs underbraced stock swingarm.
- porchev914
Re: t-dubs underbraced stock swingarm.
25 May 2010 09:44
I think I looks great Leon, awesome job! I am curious why you could tig all the joints except the front braces to the pivot? I certainly sympathize with you not having the bike there for mock ups........ it just shows how skillful and experienced a fabricater you are
Tyler is a lucky man having you for a friend!
FRANKEN Z!
- dutchz
25 May 2010 09:49 - 25 May 2010 09:52
531blackbanshee wrote:
It does. I don't have it mounted right now so these old pics are the best I got. Keep in mind this is not a stock setup, I think it may be sucked in just a little tighter and my shocks are longer. It will still give you some idea of how the pipe runs. Hope this helps...
thanks for the comments guys.
one of the hard things about trying to do custom work when you don't have the bike for test fitting,is being able to forsee all the little obstacles that can hang you up.
it looks like that yosh gets pretty cozy with the swing arm :ohmy: .
1974 Kawasaki Z1
Stock front hub and rear axle.
Last edit: 25 May 2010 09:52 by dutchz.
- dutchz
25 May 2010 09:50
1974 Kawasaki Z1
- dutchz
25 May 2010 09:50
1974 Kawasaki Z1
25 May 2010 13:11
dutchz,
thanks for the pics.i can see that your spool/shock bolts looks like a very nice solution to a tricky lil problem.
t-dub,
do you think some spool/shock bolts could work for you?
i could weld some threaded lugs on the bottom of the axle plates which looks like they would work and not be in the way.although they would look like "threaded bungs welded on the bottom of the axle plate". :huh:
not my idea of the cleanest solution but.
porchev,
the front edge of the front gusset plate and the area where the plate and pivot tube meet has a weld,i sanded it down as much as i dared to get the plate clean.tig welding is very sensitive to dirt or paint or anything that can contaminate the weld puddle.i couldn't get the front edge (where the weld was) clean enough without compromising the weld itself in order to tig weld it.there is also the front corners of the plate where the legs meet the pivot tube that were unwelded from the factory and dirt and gease had built up in there(no telling what had built up under the plate.if you penetrate 100 percent it will pull contaminates off the bottom up through the puddle).tig welding seems to draw anything within an inch of it to the weld puddle.so i mig welded those two joints.it seemed to be the best solution.otherwise you cut the plate out clean it all and weld the plate back then weld in the support tubes.okay,call me lazy for taking the easy way out. :silly:
t-dub,
porchev,
- T_Dub
25 May 2010 14:41
Ok Leon, I'll make some shock spools. Looks like thats the best option. Looks like your work is done! And what spectacular work it is!! I'm getting more excited all the time. I just tossed my cases and cylinders in the dishwasher today! Cleaned up nice! Should be able to paint them as soon as I get some free time.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- dutchz
25 May 2010 15:13
Tdub, as an aside you'll have to extend the swing arm pickups so they reach the spools. You can see the plates I welded onto my pitbull stand in the last picture.
1974 Kawasaki Z1
- T_Dub
25 May 2010 15:25
Ok, makes sense.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- T_Dub
01 Jun 2010 09:31
I have an idea for the swingarm stand that will require no modification of the stand, and not much more fabrication. I'll show you all after I get the arm back and get the solution made.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
01 Jun 2010 13:55
i hate being the holdup!
- T_Dub
02 Jun 2010 03:17
You're really not though, I need this time to get my engine built. And to arse around with a thousand little things.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
02 Jun 2010 08:00
ah,you are too good to me t_dub!
:laugh:
:laugh:
