t-dubs underbraced stock swingarm.
- T_Dub
Re: t-dubs underbraced stock swingarm.
24 May 2010 14:37
That is one awesome looking swingarm Leon!
I'm gonna be running a Yosh. I've never fitted it to the bike, so I don't exactly know where its gonna run.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- mark1122
- Keep twisting it
24 May 2010 18:47
Nice work Leon. Very nice indeed.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- dutchz
24 May 2010 19:22 - 24 May 2010 19:25
T_Dub wrote:
It may be tough to put spools on an under braced arm if you have an early yosh like this - or on a regular arm for that matter. The yosh mounts off the passenger peg an runs underneath the swingarm. Not much room inbetween pipe and arm either, IIRC.
Pic from EricHa
On mine I am using the lower shock bolt as the spool mounting location and I still had to shorten the pipe to pick the rear up with the stand.
Pic from EricHa
1974 Kawasaki Z1
Stock front hub and rear axle.
Last edit: 24 May 2010 19:25 by dutchz.
- T_Dub
25 May 2010 03:41
Yeah I was wondering about yours, whether you had to shorten it or what. I may have to go a similar route. Why did they design a pipe that made you delete the center stand and then never left any space for spools? Weird.
How about this Leon. Weld in some inserts as close to the back of the swingy as you can. I might end up doing the shock bolt thing like Sander, but I don't want to limit myself before its all together.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- mark1122
- Keep twisting it
25 May 2010 05:27
Tdub, maybe u and Leon can put your heads together and come up with something that works with a modified rear stand?
It may be simple enough to modify a stand to work around the issue?
Leon is very good at thinking outside the box, ang u have some great design skills yourself.
I had to slide a threaded rod all the way through the axle on my cbr to put mounts on it, since it had no provision on the arm.
just a thought.
just a thought.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- T_Dub
25 May 2010 05:45
I guess I could easily tap the ends of my axle and put them on that way. I think from the pics I've seen of the Yosh pipes that that might clear it. I think between that option and the shock mount option something will work.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- mark1122
- Keep twisting it
25 May 2010 05:55
Good luck with it. the arm looks Awesome.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- testarossa
25 May 2010 06:19
How do you get the rear wheel out on the stand when your spools are on the axle?
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- T_Dub
25 May 2010 06:23
Thats a good question lol.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- mark1122
- Keep twisting it
25 May 2010 06:34
I never said it was a perfect solution.lol
To be honest. i just did it for a quick fix, so i can hold the bike up for chain lubes and other maint. i still need to find a better solution. But it will be fine for most jobs, i think. i will have to weld something on the arm or just use a jack for tire changes.
as it turned out, i replaced the spools with sliders, last week. the sliders neck down on the base so i can still get the stand on them just like the spools.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
25 May 2010 06:59
thanks for the comments guys.
one of the hard things about trying to do custom work when you don't have the bike for test fitting,is being able to forsee all the little obstacles that can hang you up.
it looks like that yosh gets pretty cozy with the swing arm :ohmy: .
- T_Dub
25 May 2010 07:01
It sure looks that way. Don't worry about it Leon, I'll figure something out.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
