raising forks...
- 9am53
- homebrew, and some bbq
raising forks...
29 Mar 2010 10:34
On my KZ1000K2 project I put on some drag bars which I love and don't want to swap out BUT as an unwelcomed and unexpected side-effect I have nice dings in my new paint where my handlebars dinged the tank. I was thinking of shimming the turning lock to keep the bars from touching the tank, but then I read about raising the forks. If lets say raising the forks in the trees by 3/4" or 1" eliminates the problem would I have to shorten the rear suspension to keep things balanced, or does it matter in terms of handling?
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
- StreetfighterKz
Re: raising forks...
29 Mar 2010 10:55
If I'm following you correctly, raising the forks doesn't move the handlebars. The upper fork clamp will still bein the same position relative to your frame/tank. Your best bet is to mess with the steering stops or get a set of handlebars with a "superbike" bend to them.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- 9am53
29 Mar 2010 11:00 - 29 Mar 2010 11:03
oh yeah, now that I think about it you are right. damn. I guess I could see if I could rig up some risers...
Thanks
Thanks
'84 GPz900r
'71 CB350
'71 CB350
Last edit: 29 Mar 2010 11:03 by 9am53.
- rstnick
29 Mar 2010 11:47 - 29 Mar 2010 12:07
Not sure if the big kaws have the same stop on the frame as the 650 which is a post on the bottom of the steering area.
I put a rear axle bolt over the post of mine to stop the bars from hitting the tank.
I needed to file the inside of the nut a little to get it on.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 29 Mar 2010 12:07 by rstnick.
- 9am53
29 Mar 2010 11:53
I never thought of using a nut, that is a good idea, nice and solid...I'll try to find some that fit.
'84 GPz900r
'71 CB350
'71 CB350
- Old Man Rock
29 Mar 2010 12:00
So as not to mess with your front suspension... Have you thought of handle bar risers?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- 9am53
29 Mar 2010 12:02
yeah...in the 3rd post
Risers would be good, I am going to check out how high they would have to be to clear the tank...I don't want a streetfighter bike with chopper height risers lol.
'84 GPz900r
'71 CB350
'71 CB350
- Old Man Rock
29 Mar 2010 12:09
1-3" rise should clear the tank I would think... Easiest way to go about it....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- trianglelaguna
29 Mar 2010 14:16
see that's why i quit smoking pot......
9am53 wrote:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- 9am53
30 Mar 2010 04:59 - 30 Mar 2010 05:02
interesting, I think you are onto something there tri. I will add the beans to the chilli at the end instead of right away with the meat.
'84 GPz900r
'71 CB350
'71 CB350
Last edit: 30 Mar 2010 05:02 by 9am53.
- Old Man Rock
30 Mar 2010 05:09 - 30 Mar 2010 05:11
So instead of raising the bars an inch you'll decrease your turn radius "turn radius shim"... I got this right...:blink:
Damn, I would think this would be an easier solution but your build....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 30 Mar 2010 05:11 by Old Man Rock.
- trianglelaguna
30 Mar 2010 05:11
AHHHHH ....up with the morning bong all cleaned and iced up aye?...ahhh the first of day......
after two or three...head out work on forks will ya!!!!!!
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
