Who want's rearsets????
  • indykaw77
  • indykaw77's Avatar
Re: Who want's rearsets????
08 Mar 2007 06:34
#118342
Yes it would.....however....the sidestand will not fold up tight enough that way,...the piece that bolts around the splined shaft is in the way.....making sidestand "flap in the breeze", so to speak.....can't have that....:blink:
Kawasaki Motorcycles...because cars lean th wrong way!
  • Bdog
  • Bdog's Avatar
  • Sweep the leg johnny!!!
10 Mar 2007 09:53
#118956
rstnick, why doesn't your FRONT brake switch work? That is silly.
Bdog:unsure:
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
10 Mar 2007 16:19
#119051
I'm not sure why it doesn't work. I should put a tester on it and see if the circuit is closing.
I think it's a common problem with the pressure switches.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
10 Mar 2007 16:29
#119058
GP or 'race' shifting issues: I ran into the same thing on my 'J' project...have to use the reverse shift pattern b/c of the kick-stand...so be it, the rear-sets are too cool to worry about that.
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
22 Mar 2007 16:15
#122631
Just won a GSXR set up I'm going to use instead! No pegs but found some nice Blue ones that fit.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
24 Apr 2007 20:25
#133657
Installed the left side '04 GSXR600 pegs. Right side is waiting on missing parts. :angry:
Before:
After:
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • ScottZ
  • ScottZ's Avatar
26 Apr 2007 17:23
#134310
Doesn't that make ya sit a little crooked?:blink:
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
27 Apr 2007 08:23
#134577
No, surprisingly not. I ride with my toes on the right side peg and it evens it out. :laugh:
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • ScottZ
  • ScottZ's Avatar
27 Apr 2007 20:03
#134861
I'd love to try this with my Spectre if I could get a good deal on the rearsets. I'll have to look into it.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
09 May 2007 06:37
#138485
Right side done, just gotta test it as the brake caliper was rebuilt and new pads installed.
Before:
After:
Post edited by: rstnick, at: 2007/05/11 18:26
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • Fourtoes
  • Fourtoes's Avatar
09 May 2007 07:09
#138491
I'm liking the look of these rearsets.....Do they work with drum brakes as well as disc, as all these examples look like discs.
Cheers
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
11 May 2007 12:31
#139215
These would need some fabbing to fit a drum set-up, as the connection point on the brake pedal has an upward force when the brake pedal is pressed down.
For a drum brake, you'd like to have a forward motion to pull the drum brake's rod, like these pegs:
Post edited by: rstnick, at: 2007/05/11 15:35
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
