Who want's rearsets????
- Unhinged
Re: Who want's rearsets????
16 May 2006 17:49
Having read this thread i think im going to try and adapt a set of NSR 125 pegs [alright, rear set's] I've got in my biscuit barrel of bits, instead of trying to find original ones... ill let you know if its a success, ill even get some pics if it work's.
- Unhinged
16 May 2006 17:53
The more i think about it maybe not...
But, i might be interested in a set at the right price... seems to be the killer in the deal, the price.
- jtmcculloch
16 May 2006 18:09
looks like everyone has the same question....
what kind of price are you thinking of selling them for???
76 KZ1075
93 ZR1100
05 Honda ST1300
71 Moto-guzzi 750
93 ZR1100
05 Honda ST1300
71 Moto-guzzi 750
- HENRYJ
17 May 2006 05:11
Sorry guys-
I wimped out on the project and bout a set of GSXR rearsets off of ebay. The more I worked on it the more I realized that each model would need a different backing plate and therefore not very cost effective.
Here is what the GSXR rearsets look like
- HENRYJ
- Johnno
17 May 2006 11:56
Looks great, Henry. What model/year of bike did you take those off of? At first, they look like they bolted right on, but I guess that is just a testament to your skill.
Post edited by: Johnno, at: 2006/05/17 14:57
- HENRYJ
23 May 2006 18:17
I believe it was a 1997 GSXR750. I had to drill two holes and mount them with bolts.
Sorry-
Kid just got out of tub.....................
Sorry-
- rstnick
07 Mar 2007 19:36
Henry, what did you do to set up your rear brake light switch?
I just bought a set of VF1000R pegs and a ZX600 master cylinder and resevoir I'm going to set up. Just need to figure out the brake light as well, as my front brake light doesn't work and I NEED the back one to work.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- barney
08 Mar 2007 04:37
Rob. I got a inline pressure switch at the local Kawi dealer in Hamilton. It comes with a longer banjo bolt so it can just be butted up against the banjo fitting on the rear calipers hose,then cut the original switches connector off and soldered it on. Bobs your uncle.(no pun intended).Works great.
Post edited by: barney, at: 2007/03/08 07:38
- CoreyClough
- GPz550 Addiction
08 Mar 2007 05:28
'85 GPz550(ZX550-A2)
- indykaw77
08 Mar 2007 05:30
FWIW....this is what front pegs and linkage, and rear M/C from an '05 xz6r look like when put on a 77 kz1000a. Only "glitch" is shift pattern reversed....now GP style ( 1 up 4 down). Will confess THAT took a little "getting used to".:whistle: :huh:
Kawasaki Motorcycles...because cars lean th wrong way!
- Wirewulf
08 Mar 2007 06:24
Hey indykaw, would your shifter work normally if you inverted the splined fitting at the shifter? Just curious.
