81-82 GPz , J, LTD, CSR series Frame Bracing ?????
Re: 81-82 GPz , J, LTD, CSR series Frame Bracing ??
28 Nov 2009 20:06
PS - If you really want to get it right, you will want to check the steering head angle, I believe the LTD and GPz are different there.
- otakar
29 Nov 2009 04:28 - 29 Nov 2009 04:41
TexasKZ wrote:
You are right. I did check. The "J" has a 27.5 angle the LTD has a 29 and so dose the LTD. But I believe that the LTD/CSR has the neck at the 27.5 and achieves the 29 with the leading axle on the forks. The GPZ and the ELR also has the 29 but without the leading axle. This will make a difference. OK now that being said, what would be a proper way to re-rake this frame? This one will be much harder than a standard KZ due to all f the extra bracing already incorporated. But this is still better than the 26* on the old 900/1000 frames.PS - If you really want to get it right, you will want to check the steering head angle, I believe the LTD and GPz are different there.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 29 Nov 2009 04:41 by otakar.
- will61310
29 Nov 2009 04:39
just a thought..why not just get a gpz frame to start with?
...1980 LTD 1000...
- otakar
29 Nov 2009 04:42 - 29 Nov 2009 04:56
I would, if I could find one. What angle do most of the guys rake the old frames to?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 29 Nov 2009 04:56 by otakar.
- trianglelaguna
Re: 81-82 GPz , J, LTD, CSR series Frame Bracing ?????
29 Nov 2009 09:09
rob smith frames were the big tickett back in the day and many teams ran em....there is an e-bay member who knows the in's and out's of all kawi frames and superbike tricks...and if you sent hima p.m through contact member in e-bay.....i'm sure he would be happy to share his knowledge with you..i have exchanged a few notes with him and found him to be SUPER good on the old stories and tricks...sadly he sold a rob north frame and i failed to bid ..it went for around 600 i think....he told me that the small brace in front of the shock in the side cover area screws with mounting stock side covers.....he also is selling off really rare extras and one off stuff quite often on there...p.m sent
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- trianglelaguna
29 Nov 2009 13:37
my project bike is a 1981 kz1000j standard....and i'm "almost" positive that the frame is from that model only...that late owner may have added these braces...but i believe they are standard issue on all standard kz1000j in 1981 and 1982.....i also was pretty sure that the factory racers changed the degree on the rake on the s1 but claimed no other changes...i need to re-read the muzzy chapter in kevin camerons "top dead center" book ...because they discuss this i believe....anyone know if my 81 frame is stock braced????
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- otakar
29 Nov 2009 14:35 - 29 Nov 2009 14:53
If this is a "J" than it is not stock. The front two braces were added. Only the rear two were stock on the "J","K","M". The front braces were stock on the GPz ONLY in 81.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 29 Nov 2009 14:53 by otakar.
- otakar
29 Nov 2009 14:53 - 29 Nov 2009 14:55
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 29 Nov 2009 14:55 by otakar.
- mark1122
- Keep twisting it
29 Nov 2009 14:58
This is how pop Yosh increased the rake on Wes Cooley's 78 GS1000 superbike
"The aftermarket forks started out
with standard length tubes, but the
Yoshimuras lengthened the tubes
35mm by welding on pieces cut from a
spare fork tube. The extra tube length
increases rake by half a degree, from
26.5' to 27', and changes trail from 4.57
in. (for the stock GS1000E) to 5.90 in.,
though the steering head is not
modified. The geometry changes
contribute to top speed stability while
the extra fork tube length increases the
height of the engine side covers relative
to the ground, thus improving
cornering clearance as well. Spacers
inside the fork tubes compensate for
the lengthened tube."
What is your rake now?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
29 Nov 2009 16:08
trianglelaguna wrote:
what was the build date on frame? maybe it was built in the transition between 2 model yearsmy project bike is a 1981 kz1000j standard....and i'm "almost" positive that the frame is from that model only...that late owner may have added these braces...but i believe they are standard issue on all standard kz1000j in 1981 and 1982.....i also was pretty sure that the factory racers changed the degree on the rake on the s1 but claimed no other changes...i need to re-read the muzzy chapter in kevin camerons "top dead center" book ...because they discuss this i believe....anyone know if my 81 frame is stock braced????
- trianglelaguna
29 Nov 2009 16:19
i will record the numbers and see...i been avoiding even going near her till i'm ready to start wrestling again.....anyway i think okatar might be right ,the old owner(r.i.p) was in the process of building/painting/refitting things...and may have added em...
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- trianglelaguna
29 Nov 2009 16:24
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
