81-82 GPz , J, LTD, CSR series Frame Bracing ?????
  • otakar
  • otakar's Avatar Topic Author
27 Nov 2009 04:04 - 27 Nov 2009 10:50
#336112
Anyone know if there are any standard frame bracing improvements that can be done to a "J" series frame (LTD, CSR, GPZ, J, ETC.) I am picking up a 82 LTD frame and want to start another bike from scratch. I would like to do this NEW GPz Replica totally right, starting with the frame. The one I have just recently finished seams to still have a little wobble at very high speeds and I would like to remedy this problem on this next bike. It is not severe like on the KZ series frames but still there a little bit. The frames on the "J" series bikes already have much of the reinforcements normally installed on the earlier bikes, but I would still like to make it stiffer. (the frame that is, for all you wise guys :laugh: ) I would be quite sure that no one would make a kit for this stile frame so I would like to know what type of steel tubing I should use and where to place it. Let me rephrase that, where to place it on the frame. :silly:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 27 Nov 2009 10:50 by otakar.
  • kpier998
  • kpier998's Avatar
Re: 81-82 GPz , J, LTD, CSR series Frame Bracing ?????
27 Nov 2009 07:14
#336128
You are right that there is a good bit of bracing already present. And even new my '82 had a weave at anything above 110 mph. As it got older the weave extended to lower speeds.
It might be helpful to post pictures of the frame so that anyone that hasn't seen one can see where the braces are already. I could post a few if you need me to.
My guess is that the swingarm bushings might need attention. I will say that the cornering capability of that bike is quite good.
  • TexasKZ
  • TexasKZ's Avatar
27 Nov 2009 07:42 - 27 Nov 2009 07:43
#336130
Find a police bike frame. I don't have a picture, and it's been a while, but as I recall, there were extra tubes before and after the coils that form triangles connecting the three backbone tubes. I think there was also one between the shock mounts.
[edit] I'm not suggesting to use the police bike, just to look at the areas Kawasaiki braced on them.
Last edit: 27 Nov 2009 07:43 by TexasKZ.
  • kano
  • kano's Avatar
  • Not Another Bloody Limey!
27 Nov 2009 09:14
#336147
like these braces?
  • otakar
27 Nov 2009 10:02
#336149
That is what the frame looks like minus the extended tubes to the tail. The bike has a GS1100 box Aluminum swing arm with needle bearings installed.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
28 Nov 2009 13:27
#336296
I can't believe that no one here knows anything about beefing up these frames. Someone here has or had to race these bikes!
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
28 Nov 2009 13:58 - 29 Nov 2009 05:22
#336309
kano wrote:
like these braces?
1 thing i dont see on these frames is a brace above, and parallel to the swing arm. This was something that Tony Foale (frame guru)added to the 750 frame he did. he also added cross braces between the 2 front horizontal cross braces.
If u PM me i could email u a file with frame pics and a bit of theory.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 29 Nov 2009 05:22 by mark1122.
  • TexasKZ
  • TexasKZ's Avatar
28 Nov 2009 14:25
#336313
This frame also does not have the bracing typically found above the swingarm pivot, but EL did tolerably well on it anyway.
This is the KZ1000S1 frame
  • TexasKZ
  • TexasKZ's Avatar
28 Nov 2009 14:31
#336314
Havin trouble with pic #2...grrrrr
  • otakar
28 Nov 2009 15:37
#336320
That looks like a stock GPz1100 frame, vice the two little studs up front, and the rear cut off. Is this the original Muzzy frame or is it a replica?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • TexasKZ
  • TexasKZ's Avatar
28 Nov 2009 19:55
#336396
Posted as an original, but I'm sure you can ask the poster.
kz1000r.com/Gallery/index.php?cat=0&page=2
  • TexasKZ
  • TexasKZ's Avatar
28 Nov 2009 20:02 - 28 Nov 2009 20:04
#336399
Somewhere I have a hand-scribbled picture of a racing frame that shows bracing almost identical to the Kosman kits, except that the top shock mounts had been move forward. The frame in the pics above have the same bracing save for the litte tubes in the V just above the swingarm bolt and nut heads, and the cross and/or diagonal brace across the frame where the airbox went. Cop bike frames have the extra bracing near the coils, but obviously not the braces where the airbox goes.
Last edit: 28 Nov 2009 20:04 by TexasKZ.
