kz1000p stock to cruise sprocket
  • scubarod
  • scubarod's Avatar Topic Author
02 Nov 2009 21:23
#331228
i am new to the forum and also new to police kz1000 but am learning fast!i bought a 2001 kzpolice bike at a auction and i am sure it is geared for acceleration and not crusing and i have been reading for three days now in old forum disc.and have concluded after talking to z1enterprise(per you guys)i would like to change to a 16/37 @2.31 gear ratio or a 16/39 @2.43 i weigh around 250 lbs.any suggestions on what i may be better off with?i want to cruise at highway speeds without winding out but would also like to be able to accelerate heavely when needed.
  • MFolks
  • MFolks's Avatar
Re: kz1000p stock to cruise sprocket
02 Nov 2009 21:51
#331230
Do some careful measurement for the engine(countershaft)sprocket if you can as 16 tooth may be close to the maximum size you can use there. I use www.gearingcommander.com to help figure chain speeds and sprocket sizes.
  • scubarod
02 Nov 2009 21:56
#331232
hey thanks!i cannot get my yr model to pull up 2001 kz1000 tire size front 110/90/18 rear 120/90/18 and i think they are run flats that i also want to replace
  • bountyhunter
  • bountyhunter's Avatar
02 Nov 2009 22:44 - 02 Nov 2009 22:45
#331236
This is a ballpark: for a 250 lb rider, you can go maybe 10% lower on rear sprocket and have decent acceleration. That would lower cruise RPM by 10% below stock value.
Last edit: 02 Nov 2009 22:45 by bountyhunter.
  • 82kz1000P
  • 82kz1000P's Avatar
03 Nov 2009 16:56
#331352
My '82 kz1000 police bike's overall drive ratio is 4.924:1 in top gear (5th); seems to be a good compromise for high speed cruising and in-town use; I wouldn't mind a 6th gear, but not enough to change all the ratios. As it is, the off idle torque in 1st is nothing like a big v-twin, so you may be slipping the clutch more at starts (but you don't have to worry about riding 2-up); just some thoughts.
  • PLUMMEN
  • PLUMMEN's Avatar
03 Nov 2009 18:04
#331363
cant go wrong with a good 16/40 combination with 530 chain. :laugh:
  • otakar
  • otakar's Avatar
03 Nov 2009 18:33 - 03 Nov 2009 18:36
#331373
16t front sprockets are hard to find. I finally found one after almost a year. Now I have decided to convert to a 530 chain and sprockets. If you wish I can sell my brand new 16t J series front sprocket to you. It has never been mounted. The J series engine (which is what you have) has a different
spline from the earlier engines. I believe I paid $23 for the sprocket. I believe that the P bikes have a standard 630 chain and not a 530.
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 03 Nov 2009 18:36 by otakar.
  • otakar
  • otakar's Avatar
03 Nov 2009 18:41
#331379
Yes I just looked it up, you have a 98 link 630 chain with a 41t Rear and a 15t front sprockets.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • dragnkaw1428
  • dragnkaw1428's Avatar
03 Nov 2009 18:58
#331387
I weigh 250 and on my 77 KZ1000 streetbike i run 15/35 and have no problems on the highway
Andy
  • otakar
  • otakar's Avatar
04 Nov 2009 03:05 - 04 Nov 2009 03:07
#331417
I am 220 and I had no problem with a 15/33 on a 76 900. The J motor has a lot more power and the gear ratio in the engine is also quite a bit closer spaced.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 04 Nov 2009 03:07 by otakar.
  • scubarod
04 Nov 2009 19:48
#331599
Z1 DOES NOT STOCK A 35TOOTH REAR BUT A 14 TOOTH FRONT AND A 33 REAR WILL BE REAL CLOSE TO YOUR RATIO.DO YOU THINK THAT WILL WORK?DO YOU RECALL YOUR RPM AT 60MPH?
  • PLUMMEN
  • PLUMMEN's Avatar
05 Nov 2009 21:10
#331708
carefull running small front sprocket easy to bind/throw chain B)
