kz1000p stock to cruise sprocket
  • Old Man Rock
  • Old Man Rock's Avatar
Re: kz1000p stock to cruise sprocket
07 Nov 2009 04:44 - 07 Nov 2009 04:49
#331912
Damn edit won't allow re-imaging! :angry: :laugh:
Here's another 14/33 combo @ 8K rpm...
Now don't get your panties all in a bind for as mentioned, your gearing and other variables in the KZ1000 vs my KZ900 are most likely different and my tires are only 17" front & back...
Also, I have the program @ 8Krpm for speed depicted....
As we now, these modified performance motors have a little added zip and rpm range. Not to mention performance cams and for the fact that I increased my displacement up to 1015cc...
With that said, in running my setup, this has pretty much came out exact! One thing for sure, if your pre & post combo comes out with an increase of .1 or higher, yes you will loose some top end speed, so freakin what but you will get there a hell of a lot quicker! :evil:
It will be interesting to see how yours comes out as well.... Keep us posted!
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 07 Nov 2009 04:49 by Old Man Rock.
  • Old Man Rock
07 Nov 2009 05:43
#331920
Obviously this got me thinking me more about this... :blush: Oh well, deal with it.... :laugh: :laugh: :laugh:
As can be reviewed below for MY SETUP....
@ 15/35 OEM sprockets, 2.33 ratio @ 110.6mph @ 8Krpm....
@ Present setup 15/37 OEM sprockets, 2.46 ratio @ 104.7mph @ 8Krpm....
@ 14/33 OEM sprockets, 2.35 ratio @ 109.5mph @ 8Krpm....
So by going up 2 teeth on the rear, leaving front alone due to my ZX6 pivot tube size I gained significantly in accelerations. Yes, lost top end speed which I didn't care about in my engine build... Remember, I went with low/mid range performance in my camshaft selection...
Considering the above mentioned, 1015cc kit, Keihin CR29mm carbs and tire/rim sizes, at 65mph my tach displays 4500rpm. The Acewell 2802 tach has a +/- 300rpm tolerance... Then throw in timing advance/retarded etc... So fairly close to the calculated speed/rpm values....
2.46 - 2.33 = .13 difference! B)
2.35 - 2.33 = .02 difference! :blush:
Now if you would have went one down on the front and 2 up on the rear (14/35 combo) ... B) ....
@ 14/35 OEM sprockets, 2.50 ratio @ 103.2mph @ 8Krpm....
2.50 - 2.33 = .17 difference! :woohoo:
Just for shits&giggles....
@ 14/37 OEM sprockets, 2.64 ratio @ 97.7mph @ 8Krpm....
2.64 - 2.33 = .31 difference! :woohoo:
Good luck on keeping this front end on the ground!
In any case, seems you got the other issues resolved from last week and are back on the road... Sweet!
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • keith1
  • keith1's Avatar
07 Nov 2009 06:52
#331934
just poking around a little, i come up with 15/33 as stock
on my bike....sooooooo, i should notice something with a 14.....dont know when they ll get installed though......
07 Nov 2009 07:02
#331937
keith1 wrote:
...sooooooo, i should notice something with a 14....quote]
Yes, and especially the real important stuff like easier wheelies! :lol:
Good Luck! :)
  • Old Man Rock
07 Nov 2009 16:04
#331995
Now that combo will provide you some significant pull....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • scubarod
  • scubarod's Avatar Topic Author
07 Nov 2009 18:29
#332043
i finally ordered a 16/37 sprocket set from z1 and will have it in by next weekend for my first ride!i hope that is a good ratio!
  • scubarod
07 Nov 2009 18:37
#332048
thanks for your info! i have decided i want lower rpm at cruising speed with less accleration and z1 suggested a 16/37 which works out to about the same gear ratio as 15/35.i will install and ride and let you guys know how it feels z1 said the kz1000 will still leave rubber everywhere with that gearing
  • keith1
  • keith1's Avatar
11 Nov 2009 14:45
#332888
well i installed them this morning....what a greasy manuever that was!! it had 15/33 and i installed the 14/33 with a new chain...did i mention this was a greasy proposition?....a lot of smeg removal.....took her for a blast....slight difference ....its felt, but nothing earth shattering....spins up a little faster...kind of reminds me of putting on a set of underdrive pullies on a v-8...all in all i m happy...old stuff got replaced and she got a little more spunk........B)
  • keith1
  • keith1's Avatar
24 Nov 2009 18:28
#335726
just a little update...i got a chance last week to take it up the highway.....quite the difference !!! my first test was around town.....a bit of a difference.....highway is a totally different story.....whack it in 5th at 4k and you are gone!!:woohoo: ...i had to double check i was in 5th.!!
i usually dont do a lot of highway ,but cruising at 80 wasnt a buzzy afair......pretty good combo in my book....
