kz1000p stock to cruise sprocket
  • Old Man Rock
  • Old Man Rock's Avatar
Re: kz1000p stock to cruise sprocket
06 Nov 2009 03:53
#331714
Keep in mind, these police specials have plenty of zip with stock sprockets. They were designed for accelerations and cruise on the Highways... ever see that awesome (:blink:) 70's show called Chips! :laugh:
Plus with all the equipment they carried in the storage cases and considering how powerful these old KZ's are, hell that bike won't even know your on it @ 250 pounds...
Same time, If your looking for a little added zip (acceleration) then no more than 2 up on the rear sprocket will do just fine without over ramping the rpm @ cruise...
Just my 2 worthless cents.....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • otakar
  • otakar's Avatar
06 Nov 2009 05:17
#331722
The reason I initially elected to go to a 16t front was because of chain adjustment. You can only go so small on the rear before you run out of adjustment. The one tooth larger front will eliminate that problem. I was going to do this to the GPZ before I elected to convert to a 530. As I mentioned before the 16t countershaft sprocket was hard to find but I did manage to do so.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
06 Nov 2009 07:36
#331742
:unsure: Will this 16T fit? :unsure:
16T countershaft sprocket from Z1E
On the large fours, 15/33 or 15/35 on some models was oem for a long time, at least from 1973 Z1 through 1979 KZ1000.
Going from 15T to 16T gives a lower more relaxed rpm at cruising speeds, but slower acceleration from a stop or crawl speed.
Dropping to 14T gives faster acceleration, but with higher "buzzier" rpm cruising speed.
Both mpg and attainable top speed stay about the same with 14T or 15T or 16T.
Lots of owners have experimented with both larger and smaller countershaft sprockets, and like me, went back to stock as best overall.
It's an easy experiment that costs relatively little, and existing chain length will usually accomodate either 14T or 15T or 16T size front sprocket.
Good Luck! :)
  • otakar
  • otakar's Avatar
06 Nov 2009 07:49 - 06 Nov 2009 07:54
#331752
Z1 was where I went first to get the sprocket but it was and is out of stock. The reason was and is because the importer is out of them. They are made in England and there are none in this country. Also when I changed gear ratios both, my millage and top speed changed drastically. My low end acceleration wend down of course, but I did extend my range quite a bit.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 06 Nov 2009 07:54 by otakar.
  • keith1
  • keith1's Avatar
06 Nov 2009 16:29
#331837
Good Luck! :)
my new 14/33 and new chain came today.....i stayed with the old school 630 stuff......kinda interested in what the 14 will feel like off the line......B)
  • Old Man Rock
06 Nov 2009 16:42 - 06 Nov 2009 16:44
#331839
"kinda interested in what the 14 will feel like off the line."...
Not much of a difference really..... Sorry bud :(
NOTE: Your KZ1000 values may be slightly different but the ratios would come out the same....
Unless of course you changed some other variables such as Primary and gear ratios, tire sizes etc...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 06 Nov 2009 16:44 by Old Man Rock.
  • keith1
  • keith1's Avatar
06 Nov 2009 16:49
#331842
OMR
cool graphs dave......thanks for sticking the pin in my ballon...:laugh: ....:laugh:
  • dragnkaw1428
  • dragnkaw1428's Avatar
06 Nov 2009 17:01
#331843
scubarod wrote:
Z1 DOES NOT STOCK A 35TOOTH REAR BUT A 14 TOOTH FRONT AND A 33 REAR WILL BE REAL CLOSE TO YOUR RATIO.DO YOU THINK THAT WILL WORK?DO YOU RECALL YOUR RPM AT 60MPH?
Try Sprocket Specialists they sell any sprocket you want in steel and aluminum sprocketspecialists.com
Andy
  • Kawickrice
  • Kawickrice's Avatar
06 Nov 2009 17:10
#331846
I think you will feel the difference off the line. The highway riding will probably feel different to. Now you can compare real world results with computer generated computations.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • keith1
  • keith1's Avatar
06 Nov 2009 17:14
#331850
that's the plan....seat of the pants versus "the chart"....B)
06 Nov 2009 21:43 - 06 Nov 2009 21:55
#331898
Am uncertain of oem sprocket sizes on the 1978 KZ1000-B2 LTD, but am sure the original 1973 Z1 oem was 15/35 which stayed the same 15/35 until becoming 15/33 on the 1976 KZ900-A1 (standard model) everywhere except Italy which kept the 15/35 and the KZ900-B1 LTD which also stayed at 15/35.
If the 1978 KZ1000-B2 oem sprockets are 15/33 and the front is being changed to 14T (resulting in 14/33) -- in other words, simply dropping one tooth on the front sprocket -- that's the same as adding several teeth to the rear sprocket without changing the front, which should result in faster off-the-line acceleration, and faster roll-on acceleration in any given gear, simply because it's akin to using a lower overall gear (think roll-on in fourth as compared to roll-on in fifth).
Am betting my nickel the difference in acceleration from stop or crawl will be readily noticeable, as will the comparative roll-on acceleration (as will the buzzier higher rpm at any given cruising speed). When needing to quickly over-take and pass another vehicle, it won't be quite as necessary to down-shift from fifth to fourth gear any more, because it's already in "passing" gear. :cheer:
Am also betting the gas mileage won't be greatly diminished (about the same odometer reading between full tank and hitting reserve, but perhaps slightly less). And that maximum attainable top speed will remain about the same as with the oem sprocket sizes.
Have always preferred gearing that allows ability to barely pull red line in top gear. Under this condition with oem sprockets, would expect the countershaft sprocket with one less tooth to likely produce about the same top speed, but with rpm nudging into redline.
Anxious to hear the road test results.
Good Luck! :)
Last edit: 06 Nov 2009 21:55 by Patton.
  • Old Man Rock
07 Nov 2009 04:24
#331910
Brings up a good question, Keith, what was the original sprocket sizes?
I'll run them through the program and see what we come up with...
As reviewed in the image, was assuming you had a 15/35 combo.... If so, then the ratios/math would be ~ the same... If 15/33, then you would feel a difference in accelerations due to the smaller cc sprocket...
Ah hell, I'll just run and display and see what it comes up as....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
