Bleeding nightmare
- WTF!
Bleeding nightmare
21 Mar 2006 00:31
Having a not so fun time trying to bleed out my dual front discs on the 900. I can get a decent 'pedal' when I isolate the system up to the splitter to the left and right caliper. From there on it refuses to get hard
I have taken all the hardware off and elevated it above the MC and tried to bleed it again. Had some improvement but still a soft aerated pedal.
Anybody else dealt with this before...
- KZQ
- Administrator
Re: Bleeding nightmare
21 Mar 2006 04:02
I had the same problem. I eventually went for a vacuum pump, which didn't help either. What eventually happened is that I let it sit for a day or so and tried again. The second time a bubble of air must have migrated because it came right up. I think you're on the right track elevating the cylinders, it can't hurt.
Aren't you glad you don't have to do this stuff for a living?
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- btchalice
21 Mar 2006 04:37
hey kzcsi what is mbd?
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- Duck
- e vica na i sau na ga
21 Mar 2006 04:45
I've only done a few sets so far but it's always taken a lot of pumping. I use a jar of fluid with a bit of hose from the nipple into the jar so I can see air and so air doesn't get back through the nipple. Then I pump one side until it's flowing good and clean with no air, then switch to the other side. If still soft I go back to the first side. So far it's worked but has always taken a lot of fluid and pumping.
-Duck
-Duck
- WTF!
21 Mar 2006 08:01
Hey that's funny! - cause I used to do this for a living on light automotive petrol and diesel.
Embarressingly I was top of trade school for brakes too...
Just running out of ideas but pleased to see that the litre of fluid I have pumped through is similar to all your experiences.
Thanks for the feedback guys.
- Sandy
- Fly High,Tony
21 Mar 2006 08:30
I don't have a lot of time right now(gotta get My ass to work),but I went through the same thing,years back,and I DID post about it in the archives.You HAVE to remove the calipers and rotate them to a certain position during the bleeding process(hang then with pieces of rope).There is an area in the front calipers on these bikes that refuses to let go of a bubble!LOL...seriously though...You say You've removed all hardware...calipers too?...take them off,and insert a piece of plywood(to keep the pistons from pushing out all the way),and turn them to a different position from normal(when they're mounted on the forks).Have the bleeder valves at the highest point.
I was at it for DAZE,when I figured this out...same results as You are getting,but I did eventually get it.
Go into the archives and do a search for brake bleeding/front calipers,etc...good luck,Bud.
Post edited by: sandy, at: 2006/03/21 11:31
Post edited by: sandy, at: 2006/03/21 11:33
1977 KZ1000 A-1
- wireman
21 Mar 2006 08:45
have you tried gravity bleeding the brakes?just put rubber hoses on bleeder vales and let them drip into can or something for a while,just keep mastercylinder full and dont pump brake pedal.
goodluck,happy wrenching!
- Nevco48
21 Mar 2006 12:30
I've been having the same problem myself, so I've been watching this thread today. I'm off to the hardware store for a longer piece of tube, and new screws for the reservoir top. In the archives, there is a mention of cleaning out both little holes in the bottom of the master cylinder reservoir, I will check those too. One hint I can give is to go slowly with the pumping if the top cover is off, as you can get a little spurt of fluid if you release the lever too quickly. Cover as much of the bike as you can with a blanket or tarp so you don't get fluid on your tank or other painted parts. Sound like the voice of experience?:pinch:
- WTF!
21 Mar 2006 15:56
Nevco - I feel your pain.
Its lunchtime here in NZ and I am off to try and bleed these bastards. I have had them elevated for a day now and I hope that the air has leeched out. Good to hear Sandy's comments and I chuckled away since mine are tied up with rope right now..
Hopefully I should be in a better mood this evening.
- WTF!
22 Mar 2006 03:11
What a nightmare of an afternoon. Just could not get a pedal free of air.
Decided to start again, stripped the front calipers, replaced the seals, changed the MC, reassembled the whole unit and elevated.
Result: Nothing - worse than the 4hrs of bleeding the other day. Very frustrated and disappointed.
Q: Does anyone know of other brake units that will bolt to the forks of the Z900? Later model Kawasaki would be preferred to keep the heritage.
I have had a gut full of these things and there is an inherent design flaw in the single caliper models.
Also, is 1"11/16th or 1"5/8th piston size the stock build? Somebody has mounted one of each on the front of the bike.
CHEERS! for the replys guys.
- 900cows
22 Mar 2006 05:31
Wireman has it right.I gravity bleed mind the same way.I put a rag up aginst the caliper and tap with a soft hammer.Bubbles do get lodged.
- wireman
22 Mar 2006 06:34
atlast,all those propaganda leaflets are paying off!:woohoo: goodluck,happy wrenching!
