Cross bracing
- Yojymbo!
Cross bracing
13 Jun 2009 12:09
I have my bike down to the bare metal and have a buddy who welds fairly well. Would it be worth while to have a few cross braces thrown up behind the headers and above the inner fender?
- PLUMMEN
Re: Cross bracing
13 Jun 2009 18:08 - 13 Jun 2009 18:26
what kind of bike? B)ive heard some people go a little nuts with bracing! :laugh:
Last edit: 13 Jun 2009 18:26 by PLUMMEN.
- donthekawguy
Re: Cross bracing
14 Jun 2009 23:55
There was a post on here a couple weeks ago that was in Japanese that had pics of what they are doing. Mostly around the neck and where the frame comes together on the sides.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- irishwill
Re: Cross bracing
15 Jun 2009 02:41 - 15 Jun 2009 02:43
i wonder who that might be????
mr Plummen ....was a nasa engineer in a past life...LOL
Last edit: 15 Jun 2009 02:43 by irishwill.
Re: Cross bracing
15 Jun 2009 07:36
Re: Cross bracing
15 Jun 2009 07:45
it is also under the kz information tab,under filebase,not model-spesific, the_frame.so all can access it.
here is another diagram.
leon holmes
leon holmes
- Yojymbo!
Re: Cross bracing
20 Jun 2009 19:25
Tomorrow I'm taking it to a Navy welder that does drag bikes and the like in his spare time. He's doing the job for very cheap. I'm going with something similar to the above. I plan to cut out the triangular sheet metal area that is bellow the gastank and reinforcing the top and front. I wanted to replace it with a bar like the one above. Also a cross brace below the headers, by the airbox and the triangles with holes in them cause they look cool. I figure I might as well do it while the frame is stripped and the labor is cheap. That way this winter I can 810 a 750 or newer 650 engine out of a non running bike and just swap them, make some money while I'm at it maybe. Is it stupid to cut off the passenger peg mounts, center stand mounts and helmet lock?
Things would be so much cleaner and what pussy can't lift their bike onto a makeshift stand for maintenance?
- Yojymbo!
Re: Cross bracing
20 Jun 2009 19:35These are the points I'm speaking of, the blue parts. The Japanese were horrrible welders and it would look much better with tube bracing rather than crap welded sheet metal. Probably get better air flow to the engine as well. All in all it seems like a pretty easy job for a competant welder. Any thoughts? Other that making sure the tank cushions has a propper place to sit it should be OK correct.?.
- timebomb33
Re: Cross bracing
20 Jun 2009 19:56
tubing would look cool but flat plates work very well also and it gives you an extra place to mount things as well in fact that is where i mount my coils on two of my drag bikes.
I THINK MY POWERBAND BROKE
- KruZer
Re: Cross bracing
20 Jun 2009 21:59
Don't forget about your exhaust mounting points when cutting off the rear footpeg mounting brackets..
*1977 1000, 1975 KZ998 LSR bike.
- Bluemeanie
Re: Cross bracing
21 Jun 2009 06:30
KruZer wrote:
Good point!! I would have figured that out AFTER I cut them off! :woohoo:
- PLUMMEN
Re: Cross bracing
21 Jun 2009 16:09
do it the easy way,look in the project section under 74 turbo project! :laugh:
