rear tire placement.
  • otakar
  • otakar's Avatar
Re: rear tire placement.
29 Apr 2009 14:54
#286288
No it will not help. In 81 Kawasaki went to CV carbs. You have VN stile carbs not BS carbs which are in the book you have.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • JMKZHI
  • JMKZHI's Avatar
29 Apr 2009 15:13 - 29 Apr 2009 15:13
#286301
Not sure what good it will do, but here's the fsm supplement for your bike:
KAWASAKI KZ1000 LTD B3 SERVICE MANUAL SUPPLEMENT
And I don't know if it's needed if you get the correct FSM.
Last edit: 29 Apr 2009 15:13 by JMKZHI.
  • otakar
  • otakar's Avatar
29 Apr 2009 16:59
#286349
Here is the rear wheel/hub break down.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Kingchiefa
  • Kingchiefa's Avatar Topic Author
  • To each thier own.
30 Apr 2009 05:37
#286468
ok well I guess I am getting on the phone with Z1 and see if I can send this one back for the right one. I don't know how I could have ordered it wrong...
1979 KZ1000 ltd b3 Currently in Troy, PA. Hope to some of you on the road.
  • Kingchiefa
30 Apr 2009 06:03
#286477
ok here is the sprockets side hub assembly, if you can't see it the spacer is set into the bearing.
  • Kingchiefa
30 Apr 2009 06:04
#286478
here is the caliper side of the assembly.
  • Kingchiefa
30 Apr 2009 06:05
#286479
this is the spacer on the caliper side.
  • otakar
  • otakar's Avatar
30 Apr 2009 06:53
#286494
Pull the spacer out of the sprocket side and post a picture. I have a suspicion that the idiot took the #13 spacer (IN Diagram) and put it on the outside instead on the inside. Than he did not place any spacer on the inside and ignored the original outside spacer #4 all together. If this is true than most likely when you removed the wheel, the swing arm "snapped" together. The wheel did not just slide out. If this in fact is the condition the mechanic created, I would sue the shop because he could have killed you. By not putting the spacer on the inside, you could not properly tighten down the rear axle, and the rear bearing due to the excessive lateral pressure on it would have eventually overheated and seized.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • RonKZ650
  • RonKZ650's Avatar
30 Apr 2009 07:33
#286504
I agree it looks like #13 on the outside and #4 is probably missing. Putting #13 on the outside though I would think would make the spacers add up to too wide to fit in the swingarm space I would think. What a mess. By all odds it probably was already assembled wrong when you brought it in, but no way to know.
  • otakar
  • otakar's Avatar
30 Apr 2009 09:30 - 30 Apr 2009 09:33
#286519
Even if that was true, any professional shop that makes their living at doing this, should catch that mistake, before they put a dangerous vehicle on the road. Mimicking someone else's mistake is no excuse. This is why someone who makes no pretenses at being an expert takes it into a professional to repair. My dad won $50,000 from Ford back in 1983 for almost the same thing. A dealer overtightened a wheel bearing and my dads wheel fell off in the middle of the express way. The wheel seized up and sheared off the axle. This was on a Grand Marques Wagon.
Now- The spacer on the brake side is the correct one. You can put a wider spacer on the sprocket side, the swingarm will flex enough to stuff it in there.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 30 Apr 2009 09:33 by otakar.
  • Kingchiefa
02 May 2009 06:53
#287158
SO I ordered the missing number 4 spacer from bike bandit and they informed yesterday that the manufacturer is no longer making that rear axle collar. Anyone know anywhere else to fidn this spacer so I can ride my bike??
  • otakar
  • otakar's Avatar
02 May 2009 07:18
#287164
Can you snap a picture of all the spacers you DO have for the rear wheel? What is the Diameter of your axle? I may have one from my CSR wheel.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
