rear tire placement.
  • Russ Jackson
  • Russ Jackson's Avatar
Re: rear tire placement.
28 Apr 2009 10:12 - 28 Apr 2009 10:14
#285991
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Last edit: 28 Apr 2009 10:14 by Russ Jackson.
  • dshelly
  • dshelly's Avatar
28 Apr 2009 10:22
#285992
Holy Cow $350 !!! You could of bought the tire irons,weights and a balancer for that and done it yourself. Plus, As long as you put things back the way they came apart , You could be riding it now. Changing tires isn't brain surgery. I would definately look up the rearend on any oem parts site and print it off. Then take it to the guy who changed the tire and make him fix it.
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
  • JMKZHI
  • JMKZHI's Avatar
28 Apr 2009 10:38
#285994
By the way, where's the hitch pin or cotter pin?
Shamel, shame, shame.
  • Kingchiefa
  • Kingchiefa's Avatar Topic Author
  • To each thier own.
28 Apr 2009 11:51
#286000
I had the cotter pin out so I could adjust the wheel back to where they had it. I do have a cotter pin in there.
1979 KZ1000 ltd b3 Currently in Troy, PA. Hope to some of you on the road.
  • JMKZHI
  • JMKZHI's Avatar
28 Apr 2009 12:12
#286007
Okay, whew. How about reply #285990 - the first part?
  • Kingchiefa
29 Apr 2009 05:26
#286164
What??
  • JMKZHI
  • JMKZHI's Avatar
29 Apr 2009 06:53
#286187
My first post up there, reply #285990.
  • Kawickrice
  • Kawickrice's Avatar
29 Apr 2009 07:17
#286188
JMKZHI wrote:
Pardon my ignorance, but how can the disk be lined up properly if the wheel isn't centered right?
I to am pondering the disk alignment.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • RonKZ650
  • RonKZ650's Avatar
29 Apr 2009 07:20
#286189
$350? if that's the total including taxes, then it's not toooo much. It may be a tad high (maybe not), but I wouldn't fret over it: $105 + 125 (tires @ retail)+ 2x$15 (tubes) + 2x$3 (rim strips) + tire disposal fee + labor.
That's the question. The answer is assuming the correct spacer is used between the disc side of the wheel and the caliper, the caliper will be lined up with the disc. From there there is a spacer that goes on the chain side of the wheel and a spacer that goes between the caliper and the swingarm on that side, so goofing up those 2 spacers will offset the entire wheel and caliper is what appears to be the problem. However offsetting the caliper should make the torque link not line up with the caliper. There are 200 1000LTD guys on here every day. Someone help out king with a couple of pics?
  • KZ1979LTD
  • KZ1979LTD's Avatar
29 Apr 2009 07:29
#286191
Make sure that you are setting on the same hash marks on the adjusters or you are gonna have problems. Sounds like they screwed it all up. I have the same make as you 79' LTD B3 and it took me alot of sweat and wrenching to get it tweaked after I added a new chain. Is your bike stock or has it got modifications? Tom
  • H1Vindicator
  • H1Vindicator's Avatar
Re: ----
29 Apr 2009 08:13 - 20 Feb 2013 19:06
#286197
Last edit: 20 Feb 2013 19:06 by H1Vindicator.
  • Kingchiefa
29 Apr 2009 09:29
#286209
I believe it is all stock, the guy at the shop is swearing that he put it back together the way I brought it in. Which I have no arguement to fight with because I have only had the bike a week, I didn't notice the rear wheel assy yet.
