dual front disk from single on 650
- 77KZ650
02 Mar 2006 18:08
Hi, my 650 has a single rotor on the front wire wheel (19 inch), can I just bolt another rotor on the other side to get duals or is there something I'm forgetting? are the rotors for opposing sides different? thanks
pics to follow if needed
07 MDP Rookie of the Year
- wireman
- Visitor
Re: dual front disk from single on 650
02 Mar 2006 18:14
try and find a matched set of rotors dual disc bikes have thinner rotors or find another thick one to match yours.if you can find a caliper off a 77 bike with a single disc you should be able to use everything if your is behind fork on your bike you can take the 77 front mount caliper and put it behind fork on right side.:whistle: goodluck,happy wrenching!
- rede4u
02 Mar 2006 19:03
I think it should be a straight bolt on. Remember to increase the reservoir for the extra capacity.
- wireman
- Visitor
02 Mar 2006 19:15
the mastercylinder should be the same once you fill the system after its all together that should be it;)
- 77KZ650
02 Mar 2006 19:23
Just went out and got some pics. Would it matter if the rotors were different thicknesses? How much of a difference is there? I measured my rotor, it looked like 6mm thick. My caliper is in front of the forks, how much work is it to change it to the back? switch forks in trees?... then is there fender issues? (I read in a link on here somewhere awhile back that the bike will be more stable with the calipers mounted behind the forks)
- 77KZ650
02 Mar 2006 19:25
- 77KZ650
02 Mar 2006 19:25
- 77KZ650
02 Mar 2006 19:41
- wireman
- Visitor
02 Mar 2006 19:43
ive allways done it for cosmetic reasons.ok if yours is allready in front youll need a caliper off a bike behind the forks off left side.we used to cut the caliper mounts off and weld them on backside,but have since been told you can just swap the legs from one side to the other just make sure to keep the caps on the right legs.:whistle: goodluck,happy wrenching!
- 77KZ650
02 Mar 2006 19:57
Actually I was planning on using different calipers.... should have mentioned that I guess, they are from a 92 ZX600, saw them on ebay without a reserve and got em for $1 :woohoo: (plus shipping of course)(just won them other night, dont have them yet) I'm guessing I'll be making some custom brackets to get them to work.
- wireman
- Visitor
02 Mar 2006 20:03
what do you want for the old caliper?
![;) ;)](/media/kunena/emoticons/11.png)
- 77KZ650
02 Mar 2006 20:11
Haha honestly I have no idea what its worth, but you can have first dibs on it once I get the zx ones to work (need a back up plan if I cant figure them out lol)![:) :)](/media/kunena/emoticons/8.png)
I'll pm you once/if I get them setup
Post edited by: 77KZ650, at: 2006/03/02 23:21
