dual front disk from single on 650
  • Shoe48
  • Shoe48's Avatar
  • Live each day as it is your last
Re: dual front disk from single on 650
02 Mar 2006 21:55
#27766
2.15 stock.. 3.00 GPZ little over 3/4 inch
  • 77KZ650
  • 77KZ650's Avatar Topic Author
02 Mar 2006 22:02
#27768
Steell, I'm confused:unsure: I think I need an intro to 101 lol. Do I need another master cylinder, or will the stock one work (work well)? (I'm going to be needing great working brakes at the far end of a 1/4 mile this summer)thanks
Post edited by: 77KZ650, at: 2006/03/03 01:04
07 MDP Rookie of the Year
  • 77KZ650
04 Mar 2006 23:06
#28311
Do I need to get a larger master cylinder? (1/2 stock, up to 5/8?) thanks
Scott
  • fixer5000
  • fixer5000's Avatar
05 Mar 2006 00:32
#28319
Scott
read all this stuff...steve
kzrider.com/component/option,com_joomlab...ew/id,24883/catid,5/
kzrider.com/component/option,com_joomlab...ew/id,17871/catid,5/
1978 kz650b pretty much stock
massachusetts
  • steell
  • steell's Avatar
05 Mar 2006 08:57
#28367
1/2" master cylinder will give you a higher pressure and have a longer lever travel (faster stopping), a 5/8" master cylinder will push a larger volume of brake fuid than the 1/2" so it will have less lever travel and less pressure.
It's easier to lock the front brakes with a 1/2" cylinder than a 5/8" cylinder, some people have complained about the brakes being to touchy with the 1/2" on dual disks, while others have been happy with it. Either one works for me, but I'm a big guy with lots of hand strength :)
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
05 Mar 2006 09:26
#28372
Ditto here. :huh:
From what I remember when I swapped from the 1/2" to the 5/8" master cylinder, is that the 1/2" or 5/8" sizing isn't the differences that the pistons travel, but is actually the piston bore diameter.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • steell
  • steell's Avatar
05 Mar 2006 11:01
#28395
RetroRiceRocketRider wrote:
Ditto here. :huh:
Yeah, I'm good at confusing people :D
The 1/2" and 5/8' does describe the cylinder bore, and with a 5/8" bore for an equal amount of lever travel it moves more fluid than a 1/2" bore (more displacement).
Let's see if I can keep from making this more confusing :)
I'll use round numbers to make it easier to understand, but they are not actual dimensions.
If you have a piston with 1 square inch surface area, and you apply 1 pound of force to that piston, then you generate 1 psi (pounds per square inch).
If you have a piston with 1/2" square inch of surface area, and you apply 1 pound of force to the piston, then you generate one pound of force per 1/2" of surface area, or 2 psi (you exert the same force but on half the surface area).
Now when you create 1 psi of pressure at the piston, (apply 1 psi to the fluid) the pressure at the other end is 1 psi, but the caliper piston is much larger (I'll use 10 square inch surface area for an example). So the 1 psi of pressure you generated by squeezing the brake lever is applied to a caliper piston with 10 square inches of surface area, and you are applying 1 pound per square inch of pressure to 10 square inches, and applying 10 lbs of force to the brake pads (1 x 10 = 10). To get the same pressure with the 1/2" master cylinder you would only have to apply 1/2 pound of force to the lever.
Keep in mind that in this example I am comparing a 1/2" master cylinder to a 1" master cylinder just to try and make it easier to understand.
A larger bore master cylinder moves more fluid per inch of movement than a smaller bore master cylinder, and the calipers require a specific amount of fluid to move a specific distance. So a 1/2" master cylinder is going to require more lever travel to move that specific amount of fluid than a 5/8" master cylinder (remember displacement).
Going back to the 1/2" and 1" comparison, a 1/2" cylinder will have to move twice as far as a 1" cylinder to move an equal volume, but the 1" cylinder would require twice the lever pressure compared to the 1/2" cylinder to generate equal psi.
Clear as mud? :laugh:
Post edited by: steell, at: 2006/03/05 14:17
05 Mar 2006 11:34
#28398
My wife and I have a saying:
Math is the enemy! :woohoo:
LOL!
I "think" I understand it though.
For example, if I used a 1 1/2' wide push broom to sweep a pile of dirt, it would require less force than a 2' wide broom sweeping the same pile of dirt?
But wouldn't the amount (volume) of dirt being pushed by the 1 1/2' wide broom also be less than the 2' wide broom due to the differences in surface area that actually contacts the dirt?
I know in a master cylinder bore that the fluid can't flow over or around the piston like with a broom, so therefore the volume would/should remain consistent with identical forces applied to different sized pistons.
But I also thought that aside from the obvious longevity of hydraulic systems over cable operated systems, is that a hydraulic system is designed to require less effort or force to operate, regardless of bore/piston diameters and fluid capacities?
Dang it, now my head hurts. :huh:
I really need to limit myself to just ONE cup of coffee in the morning! :laugh:
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
  • steell
  • steell's Avatar
05 Mar 2006 12:07
#28407
You did not read the whole thing did you? :)
Your broom analogy don't really work, and it's kind of tough to compare a mechanical brake system with a hydrualic brake system, the mechanics are different.
I think it's a whole lot simpler to just say that a dual disk brake system with a 1/2" master cylinder will be more "Touchy" than one with a 5/8" master cylinder :D
I have learned better than to discuss anything technical with my wife, her eyes just glaze over :laugh:
Post edited by: steell, at: 2006/03/05 15:09
  • 77KZ650
05 Mar 2006 16:38
#28501
Ditto here. :huh:
Clear as mud? :laugh:<br><br>Post edited by: steell, at: 2006/03/05 14:17
VERY clear :) thanks a lot!!
I'll be staying with the 1/2 then, my concern was that it wasn't going to give me enough "stopping power" with 2 calipers. I'll be expecting the brakes to be much more touchy anyway since I'll be putting on the ZX calipers (I hope). And just having to pull the lever a little farther is no problem, I only drove the bike for a summer, Im sure it will be easy to get used to a new feel againB)
  • wireman
  • wireman's Avatar
05 Mar 2006 16:44
#28503
ive got a front mastercylinder for a zx-10 laying around here somewhere if you want it to match your calipers.:whistle:
  • 77KZ650
05 Mar 2006 17:01
#28509
Maybe :) have some pics of it?
