Swing Arm Info
- otakar
Re: Swing Arm Info
30 Jan 2009 05:15
Besides the price of the shock mounts you have two other problems. 1) you must pay someone to TIG weld them on. 2) the process anneals the Aluminum and the entire unit must be sent for hardening again.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- okie1
Re: Swing Arm Info
30 Jan 2009 13:23
Well i have tried to get in contact with the seller and he wont return my emails? So I guess Im on the hunt once again for a extended swing arm? If anyone has one and wants to sell it let me know.
Thanks :dry:
Thanks :dry:
1981 KZ 1000
1979 KZ 1000
1979 KZ 1000
- otakar
Re: Swing Arm Info
30 Jan 2009 14:46
It's still up for auction, just bid on it.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- timebomb33
Re: Swing Arm Info
30 Jan 2009 21:39
the 1150 arm will fit in the frame no problem the only problem is with the shock mounts the swingarm is fairly narrow right where you want to put the mounts so you would have to do some serious beefing up in that area but you could make it work. on one of my bikes i took and early zx-7 swingarm and cut the mounts for the single shock linkage and re attached them to the upper part of the swingarm and used them for shock mounts. it worked fantastic some people have said you have to reheat treat after doing this kind of thing ididn't and have had absolutely no probs with this swing arm every by the way it was a straight bolt after redoing the mounts and this swing arm gained me 2 extra inchs of wheelbase in the process one problem with it was the adjusters are eccentrics so when i adusted the chain i also had to adjust the wheelie bar heights as well but i delt with iton the whole i was quite happy with it.
I THINK MY POWERBAND BROKE
- okie1
Re: Swing Arm Info
30 Jan 2009 21:44
I got a email back from the guy so im gonna send him his 60 bucks and give it a try? Thanks for your input!!!!
1981 KZ 1000
1979 KZ 1000
1979 KZ 1000
Re: Swing Arm Info
30 Jan 2009 22:01 - 30 Jan 2009 22:46
okie1 wrote:
:huh: Is this about adapting a uni-shock swingarm to a dual shock swingarm, or about converting a dual shock rear suspension to a uni-shock rear suspension, or neither of the above, or what?
Edit -- Now clearer after re-reading timebomb's post that 1150 arm will fit in the frame, and possibility of removing the lower uni-shock mounts and re-using them as upper dual shock mounts after reinforcing the shock mount areas.
Seems the alternate swingarm choice suggested by otakar would be the easier application and avoid the cutting and welding.
Good Luck!
Good Luck!
Last edit: 30 Jan 2009 22:46 by Patton.
