Swing Arm Info
  • okie1
  • okie1's Avatar Topic Author
Swing Arm Info
28 Jan 2009 20:04
#260765
Guys i just bought this and was wondering if this is the right swing arm everyone is using? 1984 GS 1150 EF
1981 KZ 1000
1979 KZ 1000
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Swing Arm Info
28 Jan 2009 20:57
#260772
looks a little long but i guess anything is possible!B)
  • donthekawguy
  • donthekawguy's Avatar
Re: Swing Arm Info
28 Jan 2009 23:29
#260780
Everyone is using the 80-83 gs1100e arm. That one will work all you need to do is weld on the shock mounts and it should fit.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • okie1
Re: Swing Arm Info
29 Jan 2009 10:13
#260826
Thanks guys!! I should be able to find aftermarket Shock mounts? Or what do you think would work the best?
1981 KZ 1000
1979 KZ 1000
  • oldkaws4ever
  • oldkaws4ever's Avatar
  • Have no regrets...... You only live once.
Re: Swing Arm Info
29 Jan 2009 13:15
#260849
i Know jeff at Z1 enterprises sells them, i would check there first, maby someone else will chime in.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
Re: Swing Arm Info
29 Jan 2009 16:17
#260872
Did you get this really cheap on eBay? I asked a seller for some dimensions and he was totally confused :S :S For example, he told me the length was 16" - don't think so...
The Kaw List:
  • otakar
  • otakar's Avatar
Re: Swing Arm Info
29 Jan 2009 16:24
#260874
This swing arm looks like it would be more trouble to modify than it is worth. The GS1100 swing arm is the one or the Kawasaki Zephyr (750 or 1100) swing arms are the best.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • otakar
  • otakar's Avatar
Re: Swing Arm Info
29 Jan 2009 16:29
#260876
Here is a GS1100 swing arm mounted on my Scratch built GPz1100 (Built from a CSR) The shocks are for a Honda "Leadwing"
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
Re: Swing Arm Info
29 Jan 2009 17:06
#260881
This is what the swing arm you want, looks like.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • okie1
Re: Swing Arm Info
29 Jan 2009 18:29
#260889
YES!! I did $60.00 To my door. Hell if it dont work i will melt it down and make a ASH TRAY out of it and send it to Trianglelaguna!!!! LMAO!!!!
Thanks Otakar!! Hay you can sell me that one if ya not gonna use it?:unsure:
1981 KZ 1000
1979 KZ 1000
  • otakar
  • otakar's Avatar
Re: Swing Arm Info
30 Jan 2009 02:03
#260917
Actually that is an eBay picture. Here is the link for it. cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...witem=#ht_500wt_1210
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
Re: Swing Arm Info
30 Jan 2009 04:36
#260920
Z1 enterprises does have shock mounts normally, but they are out of stock at the moment (according to the website). They also cost nearly $100 which is a bummer when the whole arm costs much less than that. They are billet items though and that stuff isn't cheap...
www.z1enterprises.com/detail.aspx?ID=2043
What concerns me with that specific swingarm is the pivot axle area - it's split into 2 sections instead of being solid all the way across. Not sure how that would work but it might be OK.
The Kaw List:
