front end
  • PunkRawkKid
  • PunkRawkKid's Avatar Topic Author
front end
24 Oct 2008 04:05
#243483
im new to this forum but ive been on the kz650 forum for quite awhile now...i have a 1978 KZ650B.but anyways,
i heard it mentioned over there about someone switching out their front end to use GSXR750 front forks,triple tree, etc.they said the 00-03 model years fit pretty close to perfectly.i was wondering how true this is because i would like to do this.i would just basically switch over to that whole front end just to make things that much easier instead of piecing everything together...
im looking to do this as soon as i can but want to know how easy this will be or what issues i may run into so i can assess this swap before i dive in.
  • steell
  • steell's Avatar
Re: front end
24 Oct 2008 05:52
#243497
I have read that the GSXR forks are a lot shorter than the KZ forks, so you may want to check into that aspect.
GSX forks are real close to the same length and an easy swap.
GSX are right side up forks, unlike the GSXR upside down forks.
  • grinch77
  • grinch77's Avatar
Re: front end
24 Oct 2008 07:13
#243519
KZ650 forks are roughly 31"and some change.I measured my buddies '08 GSXR1000 forks and they are about 1" shorter than the stock KZ forks.
1978 KZ650\'82 KZ750 motor
1991 SE-R
Coweta,OK
  • PunkRawkKid
Re: front end
24 Oct 2008 09:05
#243536
how can i compensate for that 1 inch difference so i dont affect the trail, and the general height of the front end.
  • PunkRawkKid
Re: front end
24 Oct 2008 09:13
#243537
i like the look of the inverted forks like the concept of them.that is why i would like to know more about this.
i know that anything can be done,with customizing,but at the same time no one wants to take on a project that cant be finished.
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: front end
24 Oct 2008 09:32
#243541
Also when you make the swap don't forget that you'll lose 1-2" just from going from a 19" to 17" rim/tire. So make sure you compensate for that as well as the shorter forks.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • 77_650B1
  • 77_650B1's Avatar
Re: front end
24 Oct 2008 09:42
#243543
Make new Triple clamps that move the forks down?
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
  • steell
  • steell's Avatar
Re: front end
24 Oct 2008 16:35
#243588
It's my understanding that inverted forks are supposed to be stiffer than conventional forks.
My question is, does it make any difference? Can the average rider tell the difference in stiffness between the inverted forks and conventional forks?
Or is it just the coolness factor?
I don't know, so I'm asking.
  • timebomb33
  • timebomb33's Avatar
Re: front end
24 Oct 2008 17:05
#243593
before you go and do anything measure your front tire and wheel combo and compare it to measurements from a gsxr front wheel/tire the rim might be only a 17 but the tire is wider and has a different aspect ratio ill bet there isn't a whole lot of differance between those 2 tire/wheel combos in overall heights.
I THINK MY POWERBAND BROKE
  • racer54
  • racer54's Avatar
Re: front end
24 Oct 2008 17:15
#243599
I have no first-hand experience with the USD forks but a few guys who do says the bike is smoother, LOTS more stable at speed and lighter with the new forks. They are much stronger then stock forks while shaving weight. I have bben told that once you ride with a set, you won't want to ride anything else.
  • PunkRawkKid
Re: front end
24 Oct 2008 17:28
#243607
does the measuring have any effect if i was planning to go to the 17inch front wheel that is stock with those forks.im planning on switching to the whole front end from the GSXR...forks,wheel,triple tree,brakes,etc.
so that would be a total of 3 inch difference?what can be done to compensate?i know someone said something about the triple clamps and that is definitely an option that i will have to most likely do.what else can be done so i dont drastically affect the current trail?i know the trail affects the handling..
this is about the only part that im unsure about.
  • StreetfighterKz
Re: front end
24 Oct 2008 17:40
#243610
Courtesy of Powerdog Industries...
A 19" and 17" tire has a 1.6" difference in radius so like I said 1-2" difference.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
