Suggestions to make KZ1000 lighter
- Exitpupil
18 Oct 2008 21:20
How about a list of suggestions to make my 79 KZ1000LTD lighter please.
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
- timebomb33
Re: Suggestions to make KZ1000 lighter
18 Oct 2008 21:28
AFTER MARKET OR SWINGARM FROM LATE MODEL BIKE. CONVERT OVER TO 530 CHAIN AND SPROCKETS,LATE MODEL FRONT END AND BRAKES LIGHT WEIGHT CAST LATE MODEL WHEELS AND TIRES, THE STOCK FORKS,TREES AND WHEELS ARE VERY HEAVY,SO AREN'T THE STOCK CALIPERS AND ROTORS.AND IT'S ALL ROTATING MASS YOUR GETTING RID OF SO IT WILL MAKE YOUR MOTOR FEEL EVEN STRONGER CAUSE IT SPINUP FASTER.
I THINK MY POWERBAND BROKE
- PLUMMEN
18 Oct 2008 22:38
thats easy keep my ol 200 lb fat ass off of it!:laugh: what are you planning on using the bike for?
- Exitpupil
19 Oct 2008 13:53 - 19 Oct 2008 13:54
I will be using the bike for spirited street riding. Anybody weighed their bike after fork and wheel swaps? How much can I realistically expect to take off?
Last edit: 19 Oct 2008 13:54 by Exitpupil.
- timebomb33
19 Oct 2008 14:22
well ihave weighed my drag bike with the swing-arm change and wheel swap and removing all extra parts that wern't needed my bike now weighs 395 lbs,i never did weigh the individual parts but according to the manual my bike weighed about 525 dry stock,i personally think the most important weight loss came off the rotating mass lighter wheels,brake rotors, chain and sprockets, it feels like it spins up alot faster just because of those things being reduced in weight.
- Old Man Rock
19 Oct 2008 14:41
Throw her off your bike...
Swing arm and rims alone will save some weight. If you can afford the $$$, carbon fiber rims now days...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- timebomb33
19 Oct 2008 15:27
thanks omr think how much money i'll be able to save by not eating to day or any other day that image pop's into my head.
- Old Man Rock
19 Oct 2008 15:56 - 19 Oct 2008 15:57
hahhahaha... Timebomb33, put one of those on your drag bikes and you won't need a drag bar....
Calculate weight, drag, friction, distance of travel...
1/4 mile in about 3 hours... New record! :laugh:
Sorry my KZ brother, I just couldn't resist.
One thing, is that a Ninja 250? Holly smokes, if that's a 600, whoa, that is one big girl! :blink:
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 19 Oct 2008 15:57 by Old Man Rock.
- The Fish
19 Oct 2008 17:37
I usually like to start lightening with the unsprung weight by using different calipers and discs. Often times the newer discs and brake calipers(dual discs) weight less than the stock single disc alone. Using newer lighter calipers and lighter discs will not only give better braking, but will also give better handling through less unsprung weight.
I had this set up on my 76 900 for a while and it made a very noticable difference in handling and in braking. Aluminum rims (on a spoked wheel) will also save some weight.
- The Fish
19 Oct 2008 17:45When the "Little Lady" goes with me, I need these.
This set is on my Honda and the 6 piston calipers have a lot of "bling" but they are heavier than need be. They will probably be replaced with a set of 4 piston calipers as I'll lose almost 1.5 lbs of unsprung weight just by changing the calipers to 4 piston calipers.(CB 750 w/ GL 1000 forks)
Fish
19 Oct 2008 18:32 - 19 Oct 2008 18:35
Last edit: 19 Oct 2008 18:35 by Patton.
- Bad Kaw
- Flying Squirell
19 Oct 2008 18:34
Old Man Rock wrote:
Sorry brother...it's worse than that...it's a ZX11!!!
...One thing, is that a Ninja 250? Holly smokes, if that's a 600, whoa, that is one big girl! :blink:
OMR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
