ok I'm stuck
  • djnubz
  • djnubz's Avatar Topic Author
ok I'm stuck
09 Feb 2007 18:49
#111283
I decided to do a 530 conversion on my 77 kz1000. After pulling everything apart and reassembling I noticed that I don't know where one spacer goes. It looks like a think washer. I have the spacers that fit into the grease seals on both sides but I can't figure out where this one goes. The image on buykawasaki does not help. It makes it look like it goes on the sprocket side but doesn't tell you if it is really a spacer or a washer.
My second problem is that it now looks like my rim is bent. I was spinning it on the axle and it does not look true. Can I just replace the rim and re lace it to the hub? Where can I get this piece?
I can take pics if need be.
  • wireman
  • wireman's Avatar
Re: ok I'm stuck
09 Feb 2007 18:52
#111285
pics would help;)
  • djnubz
Re: ok I'm stuck
10 Feb 2007 09:04
#111343
Ok I will take pics of all the parts once I have the chance. What can I do about the rim? What is the cheapest way to get back on the road? Is it worth picking up a set of mags if I can get them cheap and if they work for my application
kzrider.com/component/option,com_joomlab...id,5/id,76838/#76838
Front Mag wheel on eBay
Rear Mag wheel on eBay
Those are some options I found but it seems to me like I should just buy a rim and have the local shop relace it for me.
Post edited by: steell, at: 2007/02/10 12:17
  • wireman
  • wireman's Avatar
Re: ok I'm stuck
10 Feb 2007 09:20
#111350
ive got some kz1000 wheels laced up with steel rims,where are you located?
  • djnubz
Re: ok I'm stuck
10 Feb 2007 10:47
#111369
Boca Raton FL, how much do you want and are they true and balanced?
  • steell
  • steell's Avatar
Re: ok I'm stuck
10 Feb 2007 12:15
#111383
Rims should be checked, and if needed trued, whenever a new tire is installed. Most motorcycle shops can true it for you, it's just a matter of adjusting the spokes.
Tires are balanced on the rim, it's a waste of time to balance a bare rim, as soon as a tire is installed the balance is gone,
  • djnubz
Re: ok I'm stuck
10 Feb 2007 14:27
#111396
I thought it came with a tire, I wasn't reading closely. I know that you can't balance a rim w/o a tire.
I would like to know where I could find a new rim to relace to my hub if that is another option.
  • wireman
  • wireman's Avatar
Re: ok I'm stuck
10 Feb 2007 14:43
#111398
ive got one sitting here with a tire on it,but the tire aint too good. its this back rim and hub.you can have it,just pay for shipping but i need the hub from your back wheel
  • djnubz
Re: ok I'm stuck
10 Feb 2007 17:52
#111431
email me at nubz69@hotmail.com. From the way I understand it, you want me to send you my hub in exchange for your wheel and hub that is in good condition and I have to pay shipping.
  • steell
  • steell's Avatar
Re: ok I'm stuck
10 Feb 2007 18:15
#111435
Are you saying that the rim moves side to side as the wheel turns?
If it is, then being a spoked wheel that's about a $20-$30 fix at any halfway decent bike shop. If the spokes are not checked and tightened when required, then the wheel gets out of true, and that's pretty common.
If it is a mag wheel, then you have to replace it, in my opinion anyway, I don't want to ride on a mag wheel that someone straightened.
  • djnubz
Re: ok I'm stuck
11 Feb 2007 09:21
#111540
it is spoked but not only does it move side to side if I slide my hand on the rim part of the wheel while it is spinning it feels like it is bent flat a little on oone part.
Can I get a new rim? If so where?
  • steell
  • steell's Avatar
Re: ok I'm stuck
11 Feb 2007 10:11
#111553
Sure, take a look at www.buchananspokes.com/
