A 3 month old battery loses its charge with 15 miles
Re: A 3 month old battery loses its charge with 15 miles
07 Aug 2026 09:14
Perfect:)
The following user(s) said Thank You: Jimbo68
- Jimbo68
07 Aug 2026 09:21
Thanks. I’ll try tomorrow or Sunday.
1981 Kawasaki KZ440-A2
- F64
- 81-KZ440D2
07 Aug 2026 10:20
Funny, I was in the same place as you with the stator wires..
Except i was swapping in 12awg tefzel wires for the old ones..
Those screws were a pain but i got them out..
I tightened the screws slightly first.. that broke them loose
81-KZ440-D2.
LIC, NY
LIC, NY
- Jimbo68
07 Aug 2026 10:35
Thanks. Did you tighten with an impact screwdriver, manually with a screwdriver, or manually with an angled screwdriver (for more torque)? I don’t want to chew them up any further than they already are, which perhaps makes Wookie58’s suggestion preferable.
cheers.
cheers.
- F64
- 81-KZ440D2
07 Aug 2026 14:00
Just a tight fitting bit on a screwdiver... but i did use an adjustable wrench to clamp the screwdriver for more torque.
I would go for the impact if you're starting to chew the screws up.
81-KZ440-D2.
LIC, NY
LIC, NY
- Jimbo68
08 Aug 2026 03:08
I’ve completed soldering and will soon be reattaching the stator cover to the bike. I’m a bit concerned about the rubber grommet that leads the two yellow wires out of the cover. I’ve pressed it back into place as well as possible but it is still riding a bit high above the edge of the cover.
Is there a torque limit for the 9 screws that attach the cover please?
Cheers
Cheers
- bound
- If you ain't HURTIN' you ain't LEARNIN'!!
08 Aug 2026 08:28
It doesnt look like there is a specified torque for most screws on the 440 so id just make sure that they are tight but not too tight that you won't be able to remove them after 400 heat cycles... that rubber grommet needs to have some liquid gasket for sealing and dont worry too much about the way its sitting because when you tighten the cover down it will press in.
1982 KZ1000M2 CSR
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
08 Aug 2026 16:30 - 08 Aug 2026 16:32
That is a Phillips bit, and it can mail a JIS screw, JIS bits are blunt, rather than pointed. This allows them to sit deeper into the screw and more fully engage the screwing surfaces.
www.z1enterprises.com/jis-screwdrivers-s...three-144-244-4.html
Last edit: 08 Aug 2026 16:32 by TexasKZ.
- Jimbo68
10 Aug 2026 06:34
Hi folks. According to the service manual, liquid gasket should be applied to the portions where they contact the crankcase mating surface.
- That reads to me that the entire surface where the gasket meets the cover/crankcase is to have it applied. Am I correct?
- The web recommends “Permatex 22072 Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker”. Would you agree that would be ok please? I can get it readily from Amazon UK so it is ideal for me.
- To which surface should the liquid gasket be applied please? Cover, crankcase, or both?
- Would it be better to apply it to the gasket rather than the mating surfaces? I think this would be more efficient but perhaps not.
- Do I avoid applying it on the rubber grommet that seals the two exiting yellow wires?
10 Aug 2026 09:11
Apply it to the grommet side then a smear of oil to the case side so when removed the gasket won't tear.
- slmjim+Z1BEBE
10 Aug 2026 14:24 - 11 Aug 2026 01:36
If a case cover like that needs to be removed, oil loss can be reduced or eliminated entirely by tilting the bike far enough over to the opposite side & resting it on a good foundation. We keep an ancient 21 volume hardcover encyclopedia set for the express purpose of creating a variable-height, non-marring surface to rest a bike on. Would recommend removing the tank if it has fuel in it & maybe draining the carbs.
EDIT: Doesn't take much tilt for most bikes. 30° ~ 45° from vertical should be plenty.
What works for us:
Assuming both mating surfaces are reasonably clean, smooth and very flat, the thinnest possible wipe of the RTV you mentioned on both gasket sides done gently while pinched between ball of the thumb thumb & whatever finger comes naturally. Doesn't take much, just a sheen. If a significant amount (more than a thread-thin bead) of RTV squeezes out when torquing the fasteners, too much has been used. Read the directions on the RTV for application timing & tightening.
Good Ridin'
slmjim & Z1BEBE
What works for us:
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 11 Aug 2026 01:36 by slmjim+Z1BEBE. Reason: Clarity
10 Aug 2026 14:27Can I also suggest removing the battery if using a "flooded" type before laying it over !!If a case cover like that needs to be removed, oil loss can be reduced or eliminated entirely by tilting the bike far over to the opposite side & resting it on a good foundation. We keep an ancient 21 volume hardcover encyclopedia set for the express purpose of creating a variable-height, non-marring surface to rest a bike on. Would recommend removing the tank if it has fuel in it & maybe draining the carbs.
What works for us:
Good Ridin'
slmjim & Z1BEBE
The following user(s) said Thank You: slmjim+Z1BEBE, Jimbo68
