dfi
- michellehillier13
dfi
18 May 2025 08:12
ok guys i have 84 kawasaki gpz 1100,, its got the 1170 kit 4 into one pipe,,,still has the factory dfi it will idle all over the place and bogs 1/8 to 1/4 throttle it pulls hard after 3000 3500 rpms seems like its too rich
- Injected
Re: dfi
18 May 2025 08:34 - 18 May 2025 08:36Search for "Kawasaki EFI Troubleshooting Manual", not sure if its on here or not, but its a good PDF manual to check thru. There should also be something in the FSM.ok guys i have 84 kawasaki gpz 1100,, its got the 1170 kit 4 into one pipe,,,still has the factory dfi it will idle all over the place and bogs 1/8 to 1/4 throttle it pulls hard after 3000 3500 rpms seems like its too rich
You probably have a sensor out of wack.
1978 KZ650B2 modified project
Last edit: 18 May 2025 08:36 by Injected. Reason: info
- gd4now
- Denco where did you go?
Re: dfi
18 May 2025 08:35
There are several docs and trouble shooting guides about EFI located in the filebase. You do need to be logged into the site and then click on filebase and choose search and use the following in the search window EFI.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: kimchella
- michellehillier13
Re: dfi
18 May 2025 14:31
all sensors have been checked they ohms out as good there's no trouble cods,,, has the stock air box still as well the tps was adjusted it idles a lil better now adjustable fuel reg and the check valve was tested good i have the book on the bike,,, am guessing the compression ratio was bumped up a bit and the pipe is the whats causing the issue??
Re: dfi
18 May 2025 16:13
Have you checked the injectors aren’t dribbling and that they “break” cleanly
- michellehillier13
Re: dfi
18 May 2025 17:51
i have not sine i dont really know how to test them i did check everything else,, i was gonna send them out have rebuilt since they are 40 years old
Re: dfi
19 May 2025 00:46You may find the below thread helpfuli have not sine i dont really know how to test them i did check everything else,, i was gonna send them out have rebuilt since they are 40 years old
1980 z1 classic fouling plugs - KZRider Forum - KZRider, KZ, Z1 & Z Motorcycle Enthusiast's Forum
The following user(s) said Thank You: michellehillier13
- michellehillier13
Re: dfi
19 May 2025 05:54
i think i got narrowed down to weak fuel pump or the injectors as you said wookie i read on another forum that the fuel pressure would need to be raised to like 40 psi vs the 36 psi i tried to adjust the fuel reg but it wont go over around 38 psi
Re: dfi
19 May 2025 06:01 - 19 May 2025 06:05
Over time the injectors clog with crystallised crap in the fuel (just like carb jets) for it to run well the injected fuel need to be "atomised" in a fine mist but clogged injectors cause "droplets" of fuel to be gobbed in. The test outlined in the link I posted allows you to "see" what is happening
You can rig a stand-alone fuel pump to pump "white spirt" through the injectors into a jar (you will need to rig a power supply to switch the injectors - the FSM advises having a light bulb in series to reduce the current through the injector) if you run them like this for 15-20 seconds you will see an improvement in the spray pattern and atomisation
Last edit: 19 May 2025 06:05 by Wookie58.
The following user(s) said Thank You: Injected, kimchella
- Injected
Re: dfi
19 May 2025 07:22 - 19 May 2025 07:43
There are lots of videos on You Tube, just search "diy fuel injector cleaning" then "diy fuel injector testing"
You can also buy pulse tester and cleaner kits on Ebay or Amazon for reasonable money.
The gas droplet "puddling" in the intake runner would present as a rich condition.
Last edit: 19 May 2025 07:43 by Injected. Reason: info
The following user(s) said Thank You: Wookie58, kimchella, michellehillier13
- michellehillier13
Re: dfi
19 May 2025 12:57
am most likely gonna change the fuel pump since am not getting proper fuel pressure..
- michellehillier13
Re: dfi
19 May 2025 13:00
i found a place that can rebuid the injectors am gonna sent them out,, and my fuel pump isnt giving the right amount of fuel pressure its lagging a bit.. thanks for the reply guys ill let you know how it goes after i swap the pump for a new one
The following user(s) said Thank You: Gdizard, Wookie58
