dfi
- Mcdroid
- Gone Kwackers
Re: dfi
19 May 2025 14:22
Make sure you post where you got your injectors serviced...others may need the same help. And welcome to KZRider.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
The following user(s) said Thank You: kimchella
- michellehillier13
Re: dfi
19 May 2025 15:19
rc fuel injection in cali does them 35 each for clean test and 94 each for brand new ones.. i figured out two issues in one stone fuel pump was weak and the regulator is no good since its only doing 30 psi when i try to adjust it the gauge drops it like 25 psi.. should be 33 at idle and 36 at full throttle so i have read...now the question is will that 3 to 6 lb cause the stumble at 1/4 to about 1/2 throttle
Re: dfi
19 May 2025 15:35
I suspect it’s injector related but fuel pressure is also critical
- michellehillier13
Re: dfi
19 May 2025 15:50
well i guess am gonna be going threw one thing at a time so nothing is missed or overlooked.. troubleshooting sucks but its how we learn i guess me i would have did the carb swap but my bf says to keep the dfi he has a red one thats carbs it was already swapped when we got it.. any through on swapping to carbs.. or keep the dfi
- riturbo
Re: dfi
19 May 2025 16:51
I sent my injectors out to rc injectors from my turbo through charlie at evergreen turbos who is an rc dealer. They came back like brand new. It was defiantly worth the money. They came back with a flo chart showing before and after.
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
The following user(s) said Thank You: Mcdroid, Wookie58
- michellehillier13
Re: dfi
19 May 2025 17:06
thats good to know... am gonna do some more tinkering with the fuel regulator see how it runs,,,then ill send out the injectors as thats the last thing to be serviced in the dfi system everything else has been double checked,,, i have two of every sensor and the ecu box ohm everything out changed everything back and fourth found the two fuel pumps both factory are weak i got a new one in there now but the regulator wont go over 30 psi,,,so its that and the injectors left then the whole system has been checked the wiring is ok nothing is green or anything threw out the wiring anything else should i check or do??
- riturbo
Re: dfi
19 May 2025 17:28
The guys on the turbo site are using these walbro pumps .
Walbro GSL 393,Fuel line layout. - 750turbo.com
Also this bosch one
Bringing an E1 back from the dead - Page 6 - 750turbo.com
Also this bosch one
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
- michellehillier13
Re: dfi
19 May 2025 17:48 - 19 May 2025 17:51
thats the fuel pump am using now,,, i need a new regulator,,, been looking online not sure which one i should get
Last edit: 19 May 2025 17:51 by michellehillier13.
- riturbo
Re: dfi
20 May 2025 04:10
This one works . My friend george in n.h. runs it on his turbo.
MITSUBISHI LANCER EVO 8 FUEL PRESSURE REGULATOR GAUGE | eBay
Few pics
Fuel regulator - Page 2 - 750turbo.com
Georges install
Project: Better late than never ! ( AKA George W's hot rod ) - Page 19 - 750turbo.com
Few pics
Georges install
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
The following user(s) said Thank You: michellehillier13
- michellehillier13
- michellehillier13
Re: dfi
20 May 2025 12:20
i read somewhere i guess people are doing some resistor mod threw the air temp sensor whats thst about
Re: dfi
20 May 2025 15:06 - 20 May 2025 15:08
Adjust the TPS and read the DFI Technical Training Notes in the site data base.......
Last edit: 20 May 2025 15:08 by Scirocco.
