KZ400 Position Lights
  • Feanor_twh
  • Feanor_twh's Avatar Topic Author
Re: KZ400 Position Lights
02 Jan 2023 04:49 - 02 Jan 2023 04:50
#878431
Finally and after many unsuccessful searches I found the solution:
- Original rim-lamp for European KZ400, part number 23006-048
- Original optics for European KZ400, part number 23007-064
The really hard part was finding these serial numbers as they don't appear in either Partzilla or any of the diagram pages I found. I had to get an european KZ400 owner to disassembly his headlight.
It remains for me to check if halogen bulbs can be attached to that optic, I still don't know the type of socket it comes with.
Thanks.
(1976) Kawasaki KZ400-D3. All original, but: electronic reg/rec (Oregon Motorcycle Parts), new handlebar controls (w/ PASS/HORN/lights switch, LED dash lights (superbrightleds.com), Dynatek coil (3ohm), MAC mufflers, HEL brake hoses, rubber fork boots, 4.00 rear tyre (Dunlop K70), chromed chainguard
Last edit: 02 Jan 2023 04:50 by Feanor_twh.
The following user(s) said Thank You: Nerdy, Wookie58
  • Nerdy
  • Nerdy's Avatar
  • Away
02 Jan 2023 11:02
#878456
Thank you for posting the answer to your problem! :-)
So many people don't do that, and we don't know if the suggestions we make are any good.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • Feanor_twh
21 Jan 2023 17:24 - 22 Jan 2023 08:50
#879132
Not so simple. I found out that to ensure future spare parts it is necessary to upgrade to H4. For this I got a complete EMGO headlight for classic Honda's that matches in measures with the KZ400 (6 1/4") but not quite on the bolt mounts
The headlight I got is 100% metal and while I still have my doubts if I'll be able to fit it into the original bowl, I'm more preocupated about the new H4 halogen bulb will melt the original plastic bowl...
Last edit: 22 Jan 2023 08:50 by Feanor_twh.
  • Feanor_twh
23 Jan 2023 03:59
#879194
Does anyone know if these old plastic bowls resist the higher heat generated by an H4 halogen bulb?
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
23 Jan 2023 04:37
#879196
To the best of my knowledge the heat (along with the light) is reflected outwards through the lens by the reflector so I can't imagine you will have a problem
The following user(s) said Thank You: Feanor_twh
