Dyna ignition and Tach/Rev Counter
  • Gdailey2112
  • Gdailey2112's Avatar
  • 82 KZ1100D1
Re: Dyna ignition and Tach/Rev Counter
20 Aug 2022 12:20
#872549
easy to wire up? 53 Euros = ?
1982 KZ1100D1
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
20 Aug 2022 14:59 - 20 Aug 2022 15:12
#872556
Yes easy to wire up. Only ignition +12 Volts, ground, signal in from one coil or pic up, signal to tach.
Last edit: 20 Aug 2022 15:12 by Scirocco.
The following user(s) said Thank You: Gdailey2112
  • Gdailey2112
  • 82 KZ1100D1
24 Aug 2022 18:03
#872790
was told by gary @ dynatek, he said just put 20 ohm resistor on blk wire
1982 KZ1100D1
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
24 Aug 2022 19:25
#872793
I'm assuming you mean a resistor between the black wire from the tach and the 1-4 coil wire?
Adding a resistor is a pretty easy thing to test, so it's worth trying.
If the problem is that the signal is too noisy, there is some chance a 20 ohm resistor might do something.  If the problem is the dwell time as loudhvx suggested, a resistor is probably not going to help and could make it worse.
Still worth a shot.
My dad's '74 Z1
'00 ZRX1100
  • Gdailey2112
  • 82 KZ1100D1
24 Aug 2022 21:37
#872798
i agree 100%, what floors me is that dynatek acted like this is the first they'd heard about the issue, then later recommended the inline resistor.
1982 KZ1100D1
  • F64
  • F64's Avatar
  • 81-KZ440D2
24 Aug 2022 22:14 - 24 Aug 2022 22:26
#872802
or use an inductive trigger that you affix to the spark plug wire.
revivalcycles.com/products/motogadget-ignition-signal-sensor
photo:motogadget
81-KZ440-D2.
LIC, NY
Last edit: 24 Aug 2022 22:26 by F64.
