Kill Switch issue (76 kz400)
  • shroomcore
  • shroomcore's Avatar Topic Author
15 Oct 2020 08:20
#836891
I've always had a sticky kill switch and I've put off fixing it. Today it crumbled on me. I was having issues getting any power when turning the key ignition to on. No neutral light or anything. So I started messing with the kill switch and it just popped right off.
This is what's left:
Attachment not found
So I'll have to order a whole new assembly, but in the meantime how can I rig this up to give me power to ride for the time being? It's one of the last warm days here in Northwest CT, I gotta try to make it out for a little while :pinch:
  • shroomcore
Re: Kill Switch issue (76 kz400)
15 Oct 2020 08:31
#836893
Did i upload the image incorrectly?
  • loudhvx
  • loudhvx's Avatar
15 Oct 2020 08:47
#836896
Going to the kill switch there is a brown wire and a red/yellow wire. Jumper the two together.
  • shroomcore
15 Oct 2020 08:55
#836898
loudhvx wrote: Going to the kill switch there is a brown wire and a red/yellow wire. Jumper the two together.
where do the two wires come from before the switch? fuses?
  • loudhvx
  • loudhvx's Avatar
15 Oct 2020 09:12 - 15 Oct 2020 09:18
#836900
They are going to be in the main harness. The brown gets power from the ignition switch and the red/yellow goes to the coils.
If you want to just hot-wire it, run a jumper from the main fuse to the ignition coil's red/yellow wire. But make sure to have the ignition switch turned on when running so the charging system works and lights work. And also make sure not to leave the jumper in place as it will kill the battery. You will also not be able to shut off the engine with the ignition switch. You will have to pull the jumper.
I would find where the right-hand switch assembly harness goes. It would be easier to jumper it that way and then the ignition switch will do everything for you. Maybe it's in the headlight bucket.
Unplugging the right-hand control harness will also disable the electric start. If you want that to work, you will have to jump the wires while the connector is plugged in.
It might be easiest to jumper the wires inside the kill switch housing. You have to take it apart to replace the switch anyway.
Last edit: 15 Oct 2020 09:18 by loudhvx.
  • shroomcore
15 Oct 2020 10:09
#836904
loudhvx wrote: They are going to be in the main harness. The brown gets power from the ignition switch and the red/yellow goes to the coils.
I’ve located the wires (brown &red/yellow coming down the right handlebar from the kill switch housing/throttle area. They rub down and under the front of the tank and I can’t really tell where they go from there without removing tank.
Can I cut them off here? And what does “jumpering” them mean exactly?
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
15 Oct 2020 11:41
#836909
I would not cut the wires where you have found them. I would open up the right hand control and jump between the brown wire and the red/yellow wire. In doing this you are bypassing the kill switch, all other things in the right hand control will function as they should.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • loudhvx
  • loudhvx's Avatar
15 Oct 2020 12:40 - 15 Oct 2020 12:42
#836920
Jumpering means connecting one existing wire to another existing wire by connecting them together directly or with a third new wire. The third new wire will just be a short wire. The short wire is the "jumper".
When jumpering, the two original wires might be cut or disconnected, or they might be left entirely in tact as they were, with the only difference being that they are now connected to each other.
In your case, what you do depends on what your overall plans are.
If you are going to replace the entire handlebar unit, including the sub-harness, then you can just cut the brown wire and yellow/red wire near where they go into the handle bar control unit and connect them together. (And insulate them with tape.)
If you are going to repair the unit and want to keep the original sub-harness, you have a few options. You can open the switch unit and disconnect the brow wire and yellow/red wire from the switch contacts and connect them together somehow. Or you could unplug that sub-harness and install a special jumper into the main-harness end of the connector to connect the brown to yellow/red. This jumper will have to have terminal ends that can plug into the harness connector. Or you could live with the hot-wire method I described earlier. This is less invasive, but less convenient.
Last edit: 15 Oct 2020 12:42 by loudhvx.
  • shroomcore
15 Oct 2020 13:27
#836922
loudhvx wrote: Jumpering means connecting one existing wire to another existing wire by connecting them together directly or with a third new wire. The third new wire will just be a short wire. The short wire is the "jumper".
Went the route of connected the two wires under the kill switch housing. No dice, maybe the issue lies elsewhere.
Any other obvious places to look for getting no power from the battery? I don’t really know where to look next.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
15 Oct 2020 13:43
#836923
The ignition switch board (bad solder Joint) and his connector plug could be an issue (no neutral light)
  • loudhvx
  • loudhvx's Avatar
15 Oct 2020 15:57 - 15 Oct 2020 15:59
#836933
Like Scirocco said, that splice only addresses the broken kill switch issue. As he said you may have a broken wire at the ignition switch.
Was it intermittent when you jiggled the key?
If it was dead solid, then maybe check the fuses for continuity.
Last edit: 15 Oct 2020 15:59 by loudhvx.
  • ckahleer
  • ckahleer's Avatar
15 Oct 2020 17:15
#836935
I have to ask. You did strip the insulation off the wires and twist the conductors together. I'm asking because from the image, it looks like the wires are side by side under the tape.
97 ZL600
94 VF750c
94 KE100
82 KZ305
