Kill Switch issue (76 kz400)
  • F64
  • F64's Avatar
  • 81-KZ440D2
Re: Kill Switch issue (76 kz400)
17 Oct 2020 17:27
#837100
Do you have a volt meter?
81-KZ440-D2.
LIC, NY
  • shroomcore
  • shroomcore's Avatar Topic Author
18 Oct 2020 07:03
#837130
F64 wrote: Do you have a volt meter?
I don’t but I’m guna try to grab one today. I have no experience using one, so any tips on where/what I should be checking would be greatly appreciated!
  • shroomcore
18 Oct 2020 07:04
#837131
Going to also pickup new fuses, which I’ve never replaced and I haven’t even located where the fuse box is yet.
  • F64
  • F64's Avatar
  • 81-KZ440D2
18 Oct 2020 09:21
#837141
You'll be fine. All of us had to start somewhere.
Let us know when you get the meter.
81-KZ440-D2.
LIC, NY
  • shroomcore
18 Oct 2020 10:41
#837153
F64 wrote: You'll be fine. All of us had to start somewhere.
The meter has been acquired...now what?
:side: :side: :side:
  • F64
  • F64's Avatar
  • 81-KZ440D2
18 Oct 2020 11:20 - 18 Oct 2020 11:38
#837161
send a picture of the meter.
i have to tell you how to set it.
you need to set meter to read DC V
bike ignition on
engine off
Black probe on negative battery post(post being the metal part of battery the negative wire is attached to)
Red probe on positive battery post
note voltage
Move red probe to the brown wire you spliced to
note voltage
Turn off bike
81-KZ440-D2.
LIC, NY
Last edit: 18 Oct 2020 11:38 by F64.
  • shroomcore
18 Oct 2020 13:09
#837174
F64 wrote: send a picture of the meter.
bike ignition on
engine off
note voltage
note voltage
Turn off bike
  • F64
  • F64's Avatar
  • 81-KZ440D2
18 Oct 2020 20:01
#837210
Put your meter dial on the green circle.
20v dc
81-KZ440-D2.
LIC, NY
  • shroomcore
20 Oct 2020 15:23
#837324
F64 wrote: Put your meter dial on the green circle.
20v dc
So when I put it on the battery terminals it reads 12.5 - then when I move it to the brown wire it reads 0.0
  • Mikaw
  • Mikaw's Avatar
20 Oct 2020 15:27
#837326
Brown wire i think is switched threw the ignition. Turn the ignition one position and put the run/stop switch in the stop so you don’t overheat the coils. Then you should have power to the brown wire.
  • shroomcore
20 Oct 2020 16:15
#837331
Mikaw wrote: Brown wire i think is switched threw the ignition. Turn the ignition one position and put the run/stop switch in the stop so you don’t overheat the coils. Then you should have power to the brown wire.
My original photo didn’t post, but my run/off switch is busted and can’t be adjusted at this point. So I can’t put it in the stop position. I think it’s permanently in the stop position. By jumpering the brown wire to the yellow/red wire I thought I was bypassing the run/off switch entirely.
  • Mikaw
  • Mikaw's Avatar
20 Oct 2020 16:50
#837334
Try black from the meter on the battery negitive, and red of the meter on the brown. Make sure you are in contact with the copper wire of the brown.
