Dynatek Dyna III kit issues? Upgrade or Revive???
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Dynatek Dyna III kit issues? Upgrade or Revive???
12 Aug 2020 08:27
#832710
The only problem I'm having with mine is the rotor is made out of aluminum and gets sloppy on the shaft. This is my second one. The other one did the same thing even when lubricated. I can see it with the timing light. I think that's the cause of the slight misfire at 35-4000 RPM. The nut has nothing to do with it. Thinking on making a collar to take up the slop.
  • z1kzonly
  • z1kzonly's Avatar
12 Aug 2020 11:42
#832730
My 1st car tire conversion experiment chassis was a 1977 900 rear drum brake. It was crude, I have no pictures! was around 1992-3. No chromoly, used mild steel. Used a car Centerline 15" rim. It was offset, only finished on 1 side. With a 2 piece homemade hub. It was ugly.
  • Mikaw
  • Mikaw's Avatar
12 Aug 2020 20:30
#832759
z1kzonly wrote: My 1st car tire conversion experiment chassis was a 1977 900 rear drum brake. It was crude, I have no pictures! was around 1992-3. No chromoly, used mild steel. Used a car Centerline 15" rim. It was offset, only finished on 1 side. With a 2 piece homemade hub. It was ugly.
Huh???
  • BOOM_FIST
  • BOOM_FIST's Avatar Topic Author
14 Aug 2020 17:54 - 14 Aug 2020 17:57
#832930
Here are a few pics.
When I picked it up:
Currently Gun Metal Plastidip:
1977 KZ900A5
Last edit: 14 Aug 2020 17:57 by BOOM_FIST. Reason: Pic
  • Mikaw
  • Mikaw's Avatar
14 Aug 2020 18:26
#832933
Looks really nice. IMO looks better primers.
I’ve been wanting to install the chrome fork dust shields this fall when I rebuild the ‘78’s front brakes. Do you know where to get them.
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Aug 2020 19:46
#832935
Z1E had them but I can't find them now.
www.z1enterprises.com/catalogsearch/resu...K+chrome+dust+covers
  • BOOM_FIST
15 Aug 2020 12:03
#832962
Mikaw wrote: Looks really nice. IMO looks better primers.
I might have an extra pair from the parts bike. Can’t remember what kind of shape they’re in. Let me check and I’ll let you know.
1977 KZ900A5
  • Mikaw
  • Mikaw's Avatar
15 Aug 2020 12:30
#832964
Thank you please PM me so your post can continue.
