Handlebar Controls
  • hardrockminer
  • hardrockminer's Avatar Topic Author
Handlebar Controls
10 Feb 2020 16:40
#818991
I would like to restore the controls on my Z1. I was wondering if anyone here does controls, or if you know someone who does them? I would be interested in doing them myself.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Handlebar Controls
10 Feb 2020 18:43
#819001
I use artist oil paint for the letters. Paint the body with semigloss black, let dry then apply the color to the recessed letters. Wipe off the excess and you're done.
  • asphalt900
  • asphalt900's Avatar
11 Feb 2020 04:34
#819007
Easy to do Hardrock, finishing-up one this morning. What year are you doing? I have an easy to do it! You don't have to try to fill each font in, just swipe.
  • asphalt900
11 Feb 2020 04:42
#819009
Here are the tools I use. using the cosmetic sponges you just swipe across the surface. First pass don't worry about leaving a haze of paint. When paint is dry, moisten a sponge with mineral spirits, blot excess on clean rag, swipe off haze. Note the shallow recesses on choke levers, this technique allows a nice crisp job.
  • hardrockminer
11 Feb 2020 05:25
#819013
Thanks for the replies. Does anyone bake the shells after painting? Should I laquer afterwards?
Asphalt, those controls look nice! Cosmetic sponges eh? Thanks for the hint.
Is there any place that supplies the internal switches and stuff?
  • asphalt900
11 Feb 2020 05:42
#819017
I'm NOT a painter but I use Low Gloss Black DE1634 Duplicolor Engine enamel with Ceramic. I blast off existing paint/corrosion, SEM self etching primer...wait.. then Dupli-Color it. They were Not glossy when NOS. The knobs (levers are still plentiful as well as Horn/Start buttons/springs (the same). Internal stuff I have Zinc re-plated as required. Wiring sheath I get in bulk from Vintage Connections as well as connector blocks and terminals. Also if your locator tab is missing, a lot I see are, I tap in a M5 grub screw.
  • 73z1
  • 73z1's Avatar
11 Feb 2020 05:51
#819019
Asphalt,
Your work is first class.
I have tried masking and spray paint and hand painting, your work is the best I have ever seen.
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
11 Feb 2020 06:04
#819021
I have 4 sets of switch blocks of which the on off switches have crumbled where do you find those?
  • asphalt900
11 Feb 2020 06:06
#819022
Thank-You! Yea I have tried it all too, paint pens, fine tipped paint brushes, all that was just a sloppy mess. Now it takes about 10 minutes to complete each switchblock. AND they are crisp characters, live and learn I suppose.
  • asphalt900
11 Feb 2020 06:09
#819023
9er rider, Crumbled? The selector knob or the internal bakelite contact pad for the slider?
  • asphalt900
11 Feb 2020 06:20
#819025
9-er, which style of switchblock on/off/on do you have? Two styles shown. The knob was never offered separately for the Z1/KZ900-1000 but I have found a way around the earlier 72-75 versions. Only the top can be used, just remove the e-clip and transfer to your existing lower plate.
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 Feb 2020 06:25
#819026
My kill switch contact plate crumbled so I used Super glue and JB Weld to beef it up. Been working since 13. Because of my cruise control I don't use it much.
