Turn signals for dummies
  • Trackerkz650sr
  • Trackerkz650sr's Avatar Topic Author
  • Banned
  • Banned
26 Mar 2019 07:35
#801066
Hi guys so basically im trying to install turn signals and have a not stock wiring harness.
I want to know if my wiring is f'd or it sounds like a faulty flasher
-Flasher 2 prong-
One prong to battery
One prong to the turn switch
-Turn switch-
Power going to switch (from flasher)
Two leads one to each side turn signal
I can get power to the correct sides
However using my test light it wasnt flashing
Just stayed steady
So my question is
Do i have the flasher installed incorrectly?
I switched the wires around on it thinking maybe it had polarity but same thing
Do all the turn bulbs need to be hooked up for it to flash? Like a load type issue
I was using my test light for testing purposes and wonder if that is giving a inaccurate view on things
Thanks fellas!!
  • martin_csr
  • martin_csr's Avatar
Re: Turn signals for dummies
26 Mar 2019 08:18 - 27 Mar 2019 05:27
#801071
I think you have to have all of the turn signals connected with bulbs installed. Additionally, sometimes modern bulbs don't work right with the old flasher, but the fix is to get an electronic flasher from the auto parts store >> they should have a heavy duty unit that's almost identical to the stock flashers. I know autozone & probably other places have Novita flashers. made in USA.
Here's a couple I linked in a topic from a while ago. Another one to consider is the yellow Novita LF12.
Novita Turn Signal Flasher. Tridon® EL12. Electro-mechanical flasher.
Novita Hazard Warning Flasher. Tridon® LL552®. Made in USA.
Last edit: 27 Mar 2019 05:27 by martin_csr.
  • Trackerkz650sr
  • Banned
  • Banned
26 Mar 2019 08:38
#801073
U rock my guy. I am using leds. Ill grab a new relay. Does it matter if its 2 or 3 pin?
  • jayrodoh
  • jayrodoh's Avatar
26 Mar 2019 12:28 - 26 Mar 2019 12:31
#801079
You can use either, typically the third pin is for a common dash light i.e. one turn signal indicator on dash or gauge. Make sure you get an LED compatible flasher. The older ones require a specific current draw to flash which is why you are not seeing that with your test light. They will state no minimum load or for LED use.
Example:
www.superbrightleds.com/moreinfo/flasher...nic-flasher/779/833/
1982 KZ750-M1 CSR
Last edit: 26 Mar 2019 12:31 by jayrodoh.
  • Trackerkz650sr
  • Banned
  • Banned
26 Mar 2019 16:38
#801091
Back again. So i hooked up all the bulbs etc
And bought an electronic flasher
It puts power to the correct side when i use the switch as it should
However it is not flashing
Even tried reversing the leads on the flasher and same thing
Do i need a led specific flasher
Or do i need a 4 pin relay wired in with the flasher?
Little confused as everything is hooked up correctly it appears
Also went back to the stock metal kz flasher with the same result
Do i need a 3 pin flasher for leds?
  • jayrodoh
  • jayrodoh's Avatar
27 Mar 2019 05:23 - 27 Mar 2019 05:24
#801109
Yes if you are using all LED's you need to use an electronic flasher for LEDs' LED's use very little amperage therefore "standard" or "electronic replacement" flashers for the mechanical flashers will not detect the load therefore they will not flash. I looked up the one you purchased and that won't work for all LED. I'm not sure the ones Martin listed will work as they don list the minimum load required and only state that they work for " incandescent bulbs or a mixture with LEDs." Sounds like it requires some standard bulbs for the load.
You don;t need a three pin unless you want to use that third connection for a single dash light. Your wiring seems correct from your description (I hope you have a fuse between battery and flasher!)
1982 KZ750-M1 CSR
Last edit: 27 Mar 2019 05:24 by jayrodoh.
  • Trackerkz650sr
  • Banned
  • Banned
27 Mar 2019 11:17
#801132
Thank u so much for checking on the relay i bought. U rock
Any idea where i can get a led one? Lol
And yes fused lol
  • jayrodoh
  • jayrodoh's Avatar
27 Mar 2019 12:03
#801136
The one I linked earlier would work. I looked at Advance Auto and Autozone websites ,looks like they don't carry them in my area. Try some local parts shops or places that customize trucks etc. otherwise you'd have to order.
www.amazon.com/Audew-Electronic-Signal-F...359&s=gateway&sr=8-6
1982 KZ750-M1 CSR
  • Trackerkz650sr
  • Banned
  • Banned
28 Mar 2019 19:17
#801199
So fellas i went and got a proper electronic flasher 3 pin
It was a el35 i believe (35 something or other)
Said it worked with leds
Hooked it up and nothing
So my question is
Have any of u done both front and rear led turns ?
If so what worked for u
Im going to do 1 of 3 things next
1. Buy a cheap standard el552 or whatever and use a load resistor
2.buy a universal led flasher off amazon and pray it works
3. Be simple and work the switch back and forth using myself as the flasher (dont wanna but aw hell lol )
Any more ideas?
  • jayrodoh
  • jayrodoh's Avatar
29 Mar 2019 03:35
#801211
Some of the three pin ones require ground, can you get a pic of the side if there is a schematic printed on it?
Load resistors work but it defeats the point of going to LEDs IMHO
1982 KZ750-M1 CSR
  • riturbo
  • riturbo's Avatar
29 Mar 2019 06:04
#801215
One of my bikes has leds. Didnt install them so not sure what flasher but the flasher has a ground . Forgot to hook it to the bat once and no blinky .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • loudhvx
  • loudhvx's Avatar
29 Mar 2019 07:35 - 29 Mar 2019 07:37
#801218
Here are some notes on old flasher units. It shows why the 3-prong needs a ground.
The Wagner 7060 was the go-to flasher for LEDs, but I don't think Wagner makes them anymore. Tyco, or some other Chinese company probably has an equivalent or even identical model now.
Last edit: 29 Mar 2019 07:37 by loudhvx.
