89 KZ1000P cutting out at high RPM
  • paultreid
  • paultreid's Avatar Topic Author
02 Mar 2019 16:10
#799541
In the fall, on the Turnpike on my way back from a nice ride in Arkansas, my KZ1000P started intermittently losing power. I pulled over and let her idle, no problem. I rev her up whilst in neutral, no problem. I get back on and as soon as I get her in the road above 3,000 rpm, the same thing starts happening. As she loses power, the tachometer needle increases. I first thought it was severe clutch slip (bike has 36k miles) so changed the clutch disks, same issue. I then changed the coils, same issue. I then changed the spark plug caps, same issue. Could this be a bad igniter? Some threads suggest fuel starvation at higher rpm, but bike was running just fine all through the rpm range before this happened, so I think it is an electrical issue. HELP!
76 Honda GL1000
77 Honda GL1000 Cafe
76 Yamaha XS750 Cafe
13 Triumph Speed Triple
89 Kawasaki KZ1000P
Re: 89 KZ1000P cutting out at high RPM
02 Mar 2019 18:15
#799543
You mention that the engine rpm increases while the bike’s speed decreases. To me that sounds like the engine is not the problem.
When the clutch is not slipping here is a specific ratio between the engine rpm and the rear wheel rpm for each transmission gear. Consider the fact that when the clutch is not slipping the rpm of the engine sprocket is directly related to the rpm of the crankshaft through the transmission. The chain connects the engine sprocket to the rear sprocket so there is zero opportunity there for slippage there, and the rear sprocket connects directly to the rear wheel so there is zero opportunity there for slippage.
So how can the engine rpm rise without increasing the rear wheel speed? I only can think of two possibilities.
1 – Possibly the engine sprocket nut is loose and the engine sprocket is slipping on the output shaft. However, this problem would very quickly result in a major problem and would be very noticeable at all engine rpm. I seriously doubt this is the problem because the bike would not function well at any speed.
2 – The clutch is slipping. This is by far the most likely cause of the problem you describe. If the clutch is not adjusted properly, if it is damaged due to wear or due to the wrong motor oil being used, it can slip at higher speeds even though the slippage may not occur or be noticeable at low speeds. This is because there is considerable less stress on the clutch when riding at low speeds compared to riding at high speeds.
I understand that you believe the clutch is not the problem, but I respectfully suggest you take more time to ensure that the clutch cable is properly adjusted at all adjustment points, that the clutch springs are tightened properly, that the clutch plates are in good condition and installed properly, and that the correct motor oil is used.
The following user(s) said Thank You: paultreid
  • paultreid
02 Mar 2019 18:40
#799545
Thanks Ed. I always use the correct motor oil. I did an oil and filter change when I bought the bike, and have done less than 1000 miles, before changing the clutch disks and changing the oil and filter again, I have been through the tensioner on the left side, under the cover and the issue is exactly the same as before. I actually think that the engine rpm is dropping during these episodes, but for some reason the Needle on the tachometer deflects quickly to the right. The other reason I don’t think it is the clutch is that no matter how hard I push the clutch ar lower rpm, the issue never, ever happens, only above 3,000rpm. Is there any additional jetting in the carbs that kicks in over 3000rpm that could be blocked? Any idea if the ignitor is prone to damage?
76 Honda GL1000
89 Kawasaki KZ1000P
  • Nebr_Rex
  • Nebr_Rex's Avatar
02 Mar 2019 18:45
#799547
Electric or mechanical tach?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • paultreid
02 Mar 2019 18:47
#799548
I actually didn’t check, is an 89 KZ1000P, just assumed it would be mechanical, but didn’t check. Will research tomorrow.
76 Honda GL1000
89 Kawasaki KZ1000P
  • M_a_t_t
  • M_a_t_t's Avatar
02 Mar 2019 19:10
#799550
99 percent sure its electric. My 83 KZ1100 is electrical.
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
  • paultreid
02 Mar 2019 20:15
#799555
If electronic, what does the behavior of the needle tell me?
76 Honda GL1000
89 Kawasaki KZ1000P
  • SWest
  • SWest's Avatar
  • 10 22 2014
02 Mar 2019 20:49
#799556
Could be somethings wrong with the ignition.
  • paultreid
03 Mar 2019 08:10
#799573
Steve, any more specific ideas on the ignition? After replacing plugs, caps, wires and coils, I am kinda stumped, which is why I raised the potential issue of the ignitor, but which to buy new would cost more than I paid for the bike!
76 Honda GL1000
89 Kawasaki KZ1000P
  • ajsfirehawk
  • ajsfirehawk's Avatar
03 Mar 2019 09:30
#799593
Nebr Rex asked the question that was in my mind as I starting reading the thread. Use your wiring diagrams to follow the wire that feeds the tach the signal and trace backwards. I'd look for any possible shorts in that wire as well as what component it comes from.
80 KZ1000 Z1 Classic
83 KZ1100 LTD
18 Z900RS
23 Mach 1
  • paultreid
10 Mar 2019 06:03
#800053
Was getting a tire repaired (roofing nail....as it turns out) this morning and whilst there, asked mechanics what they thought the issue was, 3 of them agreed that this was classic case of failed ignitor. The reason it works up to 3000 rpm and then fails is because that is the point the ignitor is supposed to kick in with another map. So, old one out and new (after market) module on order from eBay. Will update next weekend after install. Fingers crossed!
76 Honda GL1000
89 Kawasaki KZ1000P
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
10 Mar 2019 11:42
#800087
May want to check and service the mechanical advance if that hasn't been done in a while.
1982 KZ1100-A2
