- Thank you received: 1
89 KZ1000P cutting out at high RPM
- paultreid
21 Mar 2019 21:37 #800813
by paultreid
76 Honda GL1000
77 Honda GL1000 Cafe
76 Yamaha XS750 Cafe
13 Triumph Speed Triple
89 Kawasaki KZ1000P
Replied by paultreid on topic 89 KZ1000P cutting out at high RPM
So, installed new igniter and cleaned mechanical advance and guess what......same problem. Have had enough, so am off to see a bike mechanic in the morning.
76 Honda GL1000
89 Kawasaki KZ1000P
- loudhvx
- Thank you received: 1616
22 Mar 2019 09:47 - 22 Mar 2019 10:07 #800835
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic 89 KZ1000P cutting out at high RPM
Does the bike have a kickstand switch? Sometimes that circuit causes flakey ignition problems exactly as you describe, and would make an electronic tach go crazy. If the kickstand switch gets flakey, or if vibration is actually making the kickstand move, it cuts out the ignition at certain RPMs.
And, of course, any other switch in the path can cause the same problem, like a flakey kill switch or ignition switch.
I don't actually see a kickstand switch on the one KZP diagram I have. It does show an electronic tach, though.
Also, did you do any maintenance of any kind just prior to the problem showing up? Changed oil? etc?
I wouldn't trust those mechanics since there are no "maps" in the ignition. They probably are not aware of how these old bikes work.
1981 KZ550 D1 gpz.
Other links.
Last edit: 22 Mar 2019 10:07 by loudhvx.
The following user(s) said Thank You: paultreid
- Jussumguy
- Thank you received: 11
22 Mar 2019 12:32 #800850
by Jussumguy
Replied by Jussumguy on topic 89 KZ1000P cutting out at high RPM
Isn’t it just crap in the main jets?
- paultreid
04 Apr 2019 17:30 #801537
by paultreid
76 Honda GL1000
89 Kawasaki KZ1000P
Loudhvx, you nailed it. Mechanic found the issue, which was two ignition wires that were supposed to go to a kickstand switch, but which had been removed and the wires just hand wound together. Well, the two wires had come apart and were both resting in the exhaust, which was causing the intermittent connection. Funny th8ng is that the two wires were part of the wiring harnes, but the factory wiring diagram does not show this circuit!
76 Honda GL1000
89 Kawasaki KZ1000P
- loudhvx
04 Apr 2019 20:23 #801550
by loudhvx
1981 KZ550 D1 gpz.
Other links.
Wow, I almost didnt post the response since it seemed very unlikely. I wrote most of it before I could get a look at the diagram. Maybe someone installed a harness from another bike, or maybe just part of a harness.
I'm glad its working now. Thanks for the update.
1981 KZ550 D1 gpz.
Other links.
