ZN1100 Frankenbike with points !
  • jljim
  • jljim's Avatar Topic Author
14 Jan 2019 17:28
#796778
Just in case anyone else was wondering if it was possible. Kind of a crude conversion, but it starts and runs ok. Low budget fix I guess, lots of die grinder work on the housing and cover piece to make it all work. The wiring patch work inside the headlight was the surprise behind door #1, the point setup was the surprise behind door #2. A friend of mine warned my that the cheap ones are always the most expensive..........
1981 KZ650 CSR
1985 ZN 1100 LTD
1982 GS1100GL
1979 Puch Maxi ( sold to buy the 650 )
1987 GL1200 Interstate
1986 GL1200 Aspencade (parts donor)
  • loudhvx
  • loudhvx's Avatar
Re: ZN1100 Frankenbike with points !
14 Jan 2019 18:05
#796782
Wow that's a new one. You have to be pretty committed to points to do all that.
  • jljim
14 Jan 2019 18:57 - 14 Jan 2019 18:58
#796785
Added a pic of the wiring patch work behind the headlight. Thought I did that the first time.
1981 KZ650 CSR
1985 ZN 1100 LTD
1982 GS1100GL
Last edit: 14 Jan 2019 18:58 by jljim.
  • martin_csr
  • martin_csr's Avatar
15 Jan 2019 07:06 - 15 Jan 2019 07:07
#796802
I know a guy who bought a custom chopper w S&S harley-type engine. I think from suckerpunchcycles or some place like that. He converted it to points or tried to anyway, because he got sick of the problems he kept having with the electronic ignition. :blink:
Last edit: 15 Jan 2019 07:07 by martin_csr.
  • TexasKZ
  • TexasKZ's Avatar
19 Jan 2019 10:29
#797082
Die grinder?
Looks more like he unleashed a rabid beaver on the bike!
Wow!
  • jljim
18 Feb 2019 15:44
#798864
Looking ahead on the Frankenbike project, any ZN owners out there that have installed a Dyna system on their bike ? I'm pretty sure the points were mounted in the modified original housing, I have another uncut housing to use if I need it. An email to the Dyna tech line got a pretty vague reply. Hoping to use the system that's all inside and a lot less money......
1981 KZ650 CSR
1985 ZN 1100 LTD
1982 GS1100GL
  • loudhvx
  • loudhvx's Avatar
19 Feb 2019 09:54 - 19 Feb 2019 10:12
#798886
If your ZN1100 had a mechanical advancer unit, then a KZ1000 Dyna S should work without much trouble.
If your ZN1100 had electronic-advance, then you will probably need to find an advancer unit from a Kz1000 and want to confirm the timing plate of the Kz1000 will fit into the ZN1100 housing. The electronic-advance timing plate will look very different, but the older style plate might still fit, and in that case a Dyna S plate should fit.
I'll post a drawing of the timing plate.
You want to make sure you have 3 ohm or higher coils. The stock coils would have been less than 3 ohms, and not compatible with the Dyna S, so you'd need non-stock coils.
This drawing will show you the Kz1000 timing plate and where the mounting bolts will be etc. so you can compare it with the housing on your ZN1100.
Note the Kz900/1000 timing plates have those cutouts along the edge. The smaller bikes have timing plates that are plain circles.
Last edit: 19 Feb 2019 10:12 by loudhvx.
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Feb 2019 11:43 - 19 Feb 2019 11:43
#798891
By the pic it looks like a Z1/KZ plate so the Dyna S should work. Measure the diameter and post it and I can post my extra plate measurements to compare.
Last edit: 19 Feb 2019 11:43 by SWest.
  • jljim
19 Feb 2019 16:43 - 19 Feb 2019 16:44
#798901
The email I got back from Dyna suggested the DDK2-1C. I found more info on the Z1 site that indicated a different housing from a J model would be needed for that kit to fit the ZN. I attached a picture of the points plate and the mechanical advance unit that was installed with the points. The original housing was rather crudely modified to fit the plate and is probably not usable. I have a spare ZN housing, but should I be looking for a pre electronic KZ 1000 housing and cover to use with the mechanical advance ? I might be able to use the less expensive DS2 system then.
1981 KZ650 CSR
1985 ZN 1100 LTD
1982 GS1100GL
Last edit: 19 Feb 2019 16:44 by jljim.
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Feb 2019 18:02
#798904
Would the early housing bolt on? Mine looks deeper than that. Here's one I took off the bike.
  • jljim
19 Feb 2019 18:22 - 19 Feb 2019 18:24
#798906
The housing gasket # for the '79-80 A3/A4 engine shares the same ending part number -1071. The ZN housing measures 1.540 deep and 4.650 od. They sure look like the same bolt pattern.
1981 KZ650 CSR
1985 ZN 1100 LTD
1982 GS1100GL
Last edit: 19 Feb 2019 18:24 by jljim.
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Feb 2019 18:42
#798908
The crank seal looks larger. I'll take more and better measurements tomorrow using my caliper and tape.
