ZN1100 Frankenbike with points !
  • jljim
  • jljim's Avatar Topic Author
Re: ZN1100 Frankenbike with points !
20 Feb 2019 06:27 - 20 Feb 2019 18:58
#798925
The ZN seal od is about 1.185, the id about 1.250. The seal is an NGK AC1803F.
The od number I posted isn't right, I'll measure it again in the morning. My dyslexia is acting up again........
1981 KZ650 CSR
1985 ZN 1100 LTD
1982 GS1100GL
1979 Puch Maxi ( sold to buy the 650 )
1987 GL1200 Interstate
1986 GL1200 Aspencade (parts donor)
Last edit: 20 Feb 2019 18:58 by jljim.
  • SWest
  • SWest's Avatar
  • 10 22 2014
20 Feb 2019 15:10
#798947
I measured in MM's. I'll use the calipers and set it to inches. I'll post them a little later.
  • SWest
  • SWest's Avatar
  • 10 22 2014
20 Feb 2019 16:51
#798952
The seal OD is 1.573" , ID is .965" +/- .
Spare one
  • TexasKZ
  • TexasKZ's Avatar
20 Feb 2019 17:01
#798953
If you scroll down the figment chart, you will see that the ZN uses the very same seal as all the J model engines , that is all KZ1000 and 1100 from 1981 onward. It also fits all the 1000 Concours and others.
  • SWest
  • SWest's Avatar
  • 10 22 2014
20 Feb 2019 17:44
#798954
The crank pins are larger right?
  • TexasKZ
  • TexasKZ's Avatar
20 Feb 2019 18:45
#798959
  • jljim
21 Feb 2019 03:54
#798977
Measured the seal again this morning. The ID listed is about right, 1.250" or about 32 mm. The OD is about 1.890" or 48 mm. The seal part number is listed for a lot of other models but maybe not for the r/h housing ?
1981 KZ650 CSR
1985 ZN 1100 LTD
1982 GS1100GL
  • Reese4u27
  • Reese4u27's Avatar
06 Aug 2019 07:29
#808793
This 1984 ZN1100B I have is kinda weird...my rotor/advancer looks nothing like the ones I’ve seen on the kz’s ...I just ordered a factory oem electronic ignition...I have the factory kz1000 inner cover...and hoping I can use my original rotor...I read this in hopes I can get help so...help me out fellas!!
Attachment not found
82 gs850 g
82 Kz650 csr
84 ZN1100B
