Wiring help
- Ltd700 chopped
Wiring help
04 Nov 2018 22:25
Hi guys I’ve read a lot about the other problems people had and saw all the diagrams, I just could never find one that was exact. Anyways I took the harness off, cleaned up wires by taking off extra acc wires and the old junction box in general. Bought a fuse/relay box has post positive terminals and negative, was hoping to replace that cruddy junction box but when it all came down to it my lights are on 24/7 ....my starter won’t even crank over when I press the switch.... my ignition controls nothing I feel like I ruined this project... I’m very mechanical, wiring is just a different story and I need some guidance, diagrams would be appreciated to! It’s a 1984 ltd700 guessing zn? Idk I was told it was bored out all the way so I’d love to fix it. Thanks I’m advance!
Re: Wiring help
05 Nov 2018 05:52 - 05 Nov 2018 11:38
Do you have the Kawasaki factory service manual? It has wiring diagrams.
If you need a manual, search eebbaayy for KZ750 shaft manual or ZN700 manual. there are usually one or two reasonably priced.
The ZN700 junction box & wiring are more complex than most of KZ750-4 models. The 83 ZX750 GPZ has a similar junction box.
Maybe consider getting a 750-4 wire harness w fuse box (instead of trying to simplify a wire harness w junciton box). It's still going to be a pain, though. At first glance the ZX750 handlebar control wiring is kind of crazy compared to my 81 650-CSR.
Simplified wiring diagrams. KZR topic by loudhvx. bare bones for mattylight.
see pages 11-21. If you can't find a specific diagram, try the ZX750. 750F/N shaft models. 750E/H/L/R chain drive. or 650H CSR.
note: some of the wiring diagrams are no longer there (pgs. 1-10). But from pg 11-on many are still available.
Last edit: 05 Nov 2018 11:38 by martin_csr.
Re: Wiring help
05 Nov 2018 05:58 - 06 Nov 2018 10:09
Wiring stuff. Z1Enterprises.com has colored wire, terminal pins & connectors and other electrical stuff.
If you have to replace any wire, use colored wire & try to match the stock colors as best as you can.
Tools. Cycleterminal has a $32 ratcheting crimper for open barrel terminals. I already had a HF ratcheting crimper but the dies were wrong, so I got an open barrel die set off of amazon.com (the total cost ended up being about $30T for the crimper & dies). tools
cycleterminal also has a nice terminal pin extractor set which is very handy to have. white handles. crimping help
cycleterminal.com .... connectors
Last edit: 06 Nov 2018 10:09 by martin_csr.
- Ltd700 chopped
Re: Wiring help
05 Nov 2018 19:36
Wow thanks for the quick response! so I think I got it mostly, I’m having trouble with the orange wire coming from the turn signal switch. On the diagram it shows it connects to the junction box but every time I put power to the wire it just lights up both left/right indicators on the dash. I’m thinking there is a resistor before it goes to power? It should come on when actived via handlebar switch not ignition...Also the way I have my ignition turning everything on my head light/dash lights is always on, even with the headlight switch off. So what wire would that goto to make it right? It’s a red/blue wire. I’ll post a picture of the diagrams I’m using. There is also a green/black wire coming from the igniter not sure if I need it can’t find it on any diagram. Thanks for the help again its hard finding someone that actually cares
