Dyna S install on a 1982 KZ750N Spectre
  • JohnLuke
  • JohnLuke's Avatar Topic Author
  • 1982 KZ750N Spectre
29 Jun 2018 17:47
#786112
I’m a total noob a doing wiring or crimping so bear with me.
I’m installing a new ignition system on my bike that I’m building. I know how the coils mout and all. But I’m a little hesitant to do the wiring for the coils. Ik that the bottom right switch plate has 3 wires. A power and one for each coil.(1-4 and 2-3) I guess all I know is that I have 4 existing wires from the old coils. Each set has a red wire, I assume that’s the power. And one set has a green wire and the other has a black wire. My question is can I just use the old wires? And if so what wires do what?
Thanks!
Like I said I’m a noob at this. :)
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Dyna S install on a 1982 KZ750N Spectre
29 Jun 2018 17:54
#786114
This browser does not support PDFs. Please download the PDF to view it: Download PDF
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
29 Jun 2018 18:09 - 29 Jun 2018 18:13
#786115
Ive just got one for the B model installing programs on youtube are fair 2 red wires go together at the little clip plug but Ive soldered all my connections with shrink boot
Last edit: 29 Jun 2018 18:13 by 9er rider.
  • JohnLuke
29 Jun 2018 19:28
#786119
Okay, I see the diagram you sent me. Not sure what the switched 12v wire would be.
I’ll see if I can do some digging. As for the dyna s plate on the bottom right the with two wires with bullet connectors, the ones for 1-4 and 2-3. Do I chop the connectors off? I’ll see if I can do some research about dyna s.
Thanks!
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Jun 2018 20:16
#786124
Yellow and red is the power wire. You shouldn't have to cut anything off.
  • TexasKZ
  • TexasKZ's Avatar
29 Jun 2018 21:00 - 29 Jun 2018 21:02
#786125
Perhaps this will help.
www.z1enterprises.com/documents/Dyna%20D...2%20Instructions.pdf
Ooops, sorry. I see that SWest beat me to it.
Last edit: 29 Jun 2018 21:02 by TexasKZ.
  • JohnLuke
29 Jun 2018 21:18
#786126
Idk if there is a yellow and red wire. Do you mean both yellow and red wires are power?
  • JohnLuke
29 Jun 2018 21:20
#786127
Someone should totally use the wiring diagrams that y’all sent me and like point to the wires you’re talking about and send it to dyna. Lol
I’ll peel back some electrical tape to see what colors are what. The 4 wires I sent earlier, do I use them?
Thanks!
  • JohnLuke
29 Jun 2018 21:29
#786128
The only yellow red wire I can see is the one from the starter solenoid.
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Jun 2018 21:48
#786130
There should be a wire near the coils with a double hookup. That is the power wire. The green and black wires connect to the dyna pickups. Some Dyna's have a wire that connects to the oil light switch.
  • JohnLuke
30 Jun 2018 00:21 - 30 Jun 2018 07:23
#786136
I assume you’re talking about the red wires that went into my old coil?
Let me see if I get this right. The two red wires from the old coils are the power and both my new coils can hoop up to those. As for the two wires that run up from the plate on the right and they connect to the coils as well. Then I need to power the plate. So I’ll dig around until I find that yellow/red wire.
Is that all right?
So I won’t need new wire. And then I need to time it. And then I should be good to go.
Thanks!
Last edit: 30 Jun 2018 07:23 by JohnLuke.
  • JohnLuke
30 Jun 2018 19:12
#786188
Is that correct? Or do I hook up the red wire from the dyna s plate to one of the red wires the runs to the coils?
Thanks!
