Mosfit
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Nessism
  • Nessism's Avatar
Re: Mosfit
03 Oct 2017 07:49
#772252
Can't tell from your video Steve but what was the charging voltage at 5000+ rpm?
Did you run the stator wires directly into the R/R and does the power output wire and ground run directly to the battery?
  • SWest
  • 10 22 2014
Re: Mosfit
03 Oct 2017 08:14
#772254
14v lights off, just under with just the headlight, 13v with all the lights. That was at 5000 RPM. All wires hooked up except the brown one. I need a new wiring loom. Do you have a link to Ricks. Can't seem to find it.
  • Nessism
  • Nessism's Avatar
  • SWest
  • 10 22 2014
Re: Mosfit
03 Oct 2017 14:42
#772273
Looks better than the one I got from z1partsinc. More epoxy covering the windings. Good price too. I'll contact them for a more powerful one. For now I'm getting all the power I need. Both stock ones I have did the same thing. The Mosfet is letting more power get to the battery and the system. I bought the other one as well just in case. Thanks for the tip Ed.
  • SWest
  • 10 22 2014
Re: Mosfit
11 Oct 2017 18:43
#772747
Got the newer one and installed it. I'm more confident in this one.
