Mosfit
Mosfit
13 Sep 2017 16:33
No eBay APP ID and/or Cert ID defined in Kunena configurationFound this. I should have bought this one. Hope my new one is this good. It won't come with the hook up's this one does.
adventuremotorcycle.com/news/rmstator-mosfet-regulator-kit
Re: Mosfit
13 Sep 2017 16:58
That's a knockoff of a Shindengen.
The real deal Shindengen MOSFET shunt units have a model number that starts with FH (FH008, FH010, FH012 and others).
The SH775 also looks like that but uses SERIES R/R technology which is superior. Helps protect your stator.
Re: Mosfit
13 Sep 2017 17:04
Do you have a link to the ones you've been talking about. I tried to find them but no luck.
Re: Mosfit
13 Sep 2017 18:25 - 13 Sep 2017 18:28
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
Last edit: 13 Sep 2017 18:28 by Nessism.
Re: Mosfit
14 Sep 2017 06:58 - 14 Sep 2017 07:02
BTW, Triumph P/N T2500676 is for a jumper harness that you can easily modify to install one of these R/R units on your bike. They cost about $10. If you want to go even cheaper, just use common crimp on spade terminals on the end of the wires plugging into the unit. To waterproof, fill the cavity in the R/R with electrical safe (low acid) RTV. I work in the aerospace industry and we seal electrical connections using this method. Only real downside is it's messy and reduces ease of service.
Last edit: 14 Sep 2017 07:02 by Nessism.
Re: Mosfit
14 Sep 2017 07:11
No eBay APP ID and/or Cert ID defined in Kunena configurationMine will be here today. If it's a knock off I'll send it back.
Re: Mosfit
14 Sep 2017 07:19
Check for the printing on the top edge like shown in the photos. If it's a real Shindengen part the SH775... printing will be there.
Re: Mosfit
14 Sep 2017 08:23
Will do, thanks.
Re: Mosfit
14 Sep 2017 17:26
Made in Taiwan. Nowhere does it say SH 775. I'll see if it works.
Re: Mosfit
14 Sep 2017 18:06
For $66 it ain't the end of the world.
Re: Mosfit
14 Sep 2017 18:17
Glad I didn't pay $98 plus shipping.
Re: Mosfit
14 Sep 2017 21:24
