New ignition coil won't fit OEM bracket
- russell7
20 Nov 2016 17:51
I bought an inexpensive ignition coil but it's a bit smaller than the original and won't fit the OEM bracket. They didn't seem to offer a bracket of their own. Any suggestions? Will I just have to modify the existing bracket? It's a 1980 KZ 440 LTD.
Thanks!
Thanks!
1980 KZ440 LTD
Trying to convert Grandpa's old bike into a cafe racer!
- GPzMOD750
Re: New ignition coil won't fit OEM bracket
20 Nov 2016 18:04 - 21 Nov 2016 06:25
Many wonderous things have been done with aluminum flat stock, angle brackets, stacked washers, spacers and long bolts. Use your imagination but make sure the coil/wires don't interfere with the tank or anything else.
Last edit: 21 Nov 2016 06:25 by GPzMOD750.
The following user(s) said Thank You: russell7
- azman857
20 Nov 2016 18:29
Yeah, making brackets and other "custom" parts is what makes your bike truely YOURS. Besides, it's great fun.
21 Nov 2016 05:52
L-brackets from the hardware store might work. I made brackets from aluminum angle bar from the home depot.
prototype.
prototype.
- GPzMOD750
21 Nov 2016 06:24
I made some out of scrap stainless sheet left over from adapting a ZR7 fender delete kit to fit my GPz750.
21 Nov 2016 06:35 - 21 Nov 2016 06:36
It's sometimes helpful to remember when attaching the coil in position that the coil need NOT be grounded and will perform even if suspended in mid-air.
Last edit: 21 Nov 2016 06:36 by Patton.
21 Nov 2016 07:19
Mounted to the frame provides a heat sync to cool the coil. It is best to have them firmly bolted to the frame.
- diggerdanh
22 Nov 2016 07:05
I ran into the same thing when using an Emgo coil on my 76 KZ400. IIRC I used one of the existing holes and just drilled a new hole in the bracket for the other bolt and used a nut on the back. I used the stock spacers.
- russell7
22 Nov 2016 07:39 - 22 Nov 2016 07:39
Drilling a new hole is exactly what I was thinking. I appreciate all you guys!
1980 KZ440 LTD
Last edit: 22 Nov 2016 07:39 by russell7.
