how do I know whick coil is 1-4 and 2-3
- Malcflo
24 Sep 2016 23:26
Hi,
I will really appreciate if you can help me figure out how to get my bike started.
I am new to this, how can I tell which is coil 1-4 and 2-3
and how do I connect the cables?
i bought a Dyna ds2-2 ignitioin for my 1984 KZ700 a1
- loudhvx
Re: how do I know whick coil is 1-4 and 2-3
24 Sep 2016 23:37 - 24 Sep 2016 23:46
Are you using the original harness, or did the Dyna ignition come with it's own harness?
I assume you know the two outside cylinders are 1 and 4, and so the coil connected to those plugs is the 1-4 coil.
On the smaller bikes 500 to 750, the 1-4 coil was originally mounted on the right side as you sit on the bike.
By the way, it looks like you have stock coils in that photo. Dynatek says you should not run the Dyna S ignition with those coils or it can damage the Dyna S. You need coils that are 3 ohms or higher. Your stock coils were originally 2.3 ohms.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 24 Sep 2016 23:46 by loudhvx.
The following user(s) said Thank You: Malcflo
- loudhvx
24 Sep 2016 23:43
I found my Dyna S image.
Attachment DynaSwiring.GIF not found
1981 KZ550 D1 gpz.
Other links.
Other links.
- loudhvx
24 Sep 2016 23:48 - 24 Sep 2016 23:49
This is a double post on the same subject. I replied in your original post.
www.kzrider.com/forum/4-electrical/60395...-coil-is-1-4-and-2-3
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 24 Sep 2016 23:49 by loudhvx.
- Malcflo
24 Sep 2016 23:50
I checked with the multimeter and I got 3.5 ohms..
Is that ok?
Is that ok?
- Malcflo
24 Sep 2016 23:52
But I don't know if 1-4 is on the left side looking to the front or in the right side.
- loudhvx
24 Sep 2016 23:54 - 24 Sep 2016 23:55If they are the original coils, the resistance is too high and the coils are bad or the meter is measuring incorrectly.Malcflo wrote: I checked with the multimeter and I got 3.5 ohms..
Is that ok?
If they are points coils, the resistance is too low and the coils are bad or the meter is measuring incorrectly.
If they are some other coils, and they measure 3.5 ohms, and the meter is correct, they should be fine, but the coils in the photo look like the original factory coils, which would not be ok to use.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 24 Sep 2016 23:55 by loudhvx.
- loudhvx
24 Sep 2016 23:56 - 24 Sep 2016 23:58Sorry, I edited my original post.Malcflo wrote: But I don't know if 1-4 is on the left side looking to the front or in the right side.
loudhvx wrote: I assume you know the two outside cylinders are 1 and 4, and so the coil connected to those plugs is the 1-4 coil.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 24 Sep 2016 23:58 by loudhvx.
- Malcflo
24 Sep 2016 23:59
Ok, so 1-4 are in the right hand side..
I will try like you say,
Connecting 1-4 on the right side and then left 2-3 then with the testing light follow the instructions on the dyna ignition manual.
- loudhvx
25 Sep 2016 00:06Malcflo wrote: Ok, so 1-4 are in the right hand side..
The physical location of the coils does not matter, electrically. It only matters that you connect the correct wire to the correct coil.
When pistons 1 and 4 are near the top, the magnet on the Dyna S rotor should point backward, toward the rear pickup (the pickup closer to the back of the bike). When pistons 2 and 3 are near the top, the magnet on the Dyna S rotor should point toward the front pickup (the pickup closer to the front of the bike).
Then the black wire goes to the 1-4 coil, and the green wire goes to the 2-3 coil.
1981 KZ550 D1 gpz.
Other links.
Other links.
- loudhvx
25 Sep 2016 00:09
Also, most people say to not use the splice connector. It does not work well and causes problems. Splice each wire manually.
1981 KZ550 D1 gpz.
Other links.
Other links.
- Malcflo
25 Sep 2016 00:09
I think they are not the original coils,, I bought them like 2 years ago.
I has looking for a serial number but they have none. How can I tell ?
Yeez... i know very little :S I just got tired of waiting for a good mechanic and well Ím trying no to tackle this in my
Own..
Own..
