1980 kz750 weak spark, first post
- sleazymyk
22 Aug 2016 19:00
So guys I have been searching this forum for 2 days trying to answer my own questions but I decided to pipe up to see if I could get the answer I am looking for. I am working on a 1980 kz 750, it originally came to me needing a starter clutch. I replaced that without hearing the engine run, now it cranks great but I haven't got the bike to fire. Tests showed weak spark, and I found a pickup coil that when current was applied to it it would fluctuate resistance, while the other coil stayed steady. So I had the bikes owner order a Dynatek ds2 for the bike.
My question, which has been partially answered by searching through the forum, is does the dynatek ignition bypass the stock IC ignitor? If so, does anyone have pictures of what they did with the IC ignitor? Also, will I need the owner to order some higher resistance coils, and plug wires?
FYI owner also wanted to add pod filters and 4:1 header to the bike before we got it running. So we have the carbs jetted for the pipe and filters, just trying to get the last part of the equation in working order.
Re: 1980 kz750 weak spark, first post
22 Aug 2016 19:10
The Dyna S requires coils with resistance between 3-5 ohms. To install the Dyna S just follow the directions. The system completely bypasses the ignitor. While you are working on the bike you may want to check the voltage at the coils. You should have about 11 volts or thereabouts.
The following user(s) said Thank You: sleazymyk
23 Aug 2016 06:12 - 23 Aug 2016 10:30
I'm pretty sure Dynatek recommends their green 3.0 ohm coils for the Dyna-S. Z1Enterprises.com has them.
The ignition system instructions are linked in the Dyna-S product description at Z1Ent.
Mounting Dyna coils. You'll need to install mounting brackets to mount the new coils. Some guys use L-brackets from the hardware store, 2 per side. I made brackets from angled aluminum bar from the home depot to offset the coils for better clearance of the spark plug wires.
..... prototype.
..... prototype.
Last edit: 23 Aug 2016 10:30 by martin_csr.
- sleazymyk
23 Aug 2016 09:55
Thanks guys, I checked both primary and secondary circuit in the coils and they're not open or short, and I have both good voltage and grounds on the primary circuits.
The instructions did not mention anything about the igniter and that's why I was confused. Should I leave the igniter on the bike and plugged in?
23 Aug 2016 10:33
No the "grounds" go to the pickups for 1/4, 2/3.
23 Aug 2016 11:47
I don't think it matters if you leave the ignitor or take it out. If you are going to remove it and just throw it away please hit me up, I wouldn't mind getting my hands on a cheap backup.
- OLJOCLARK
19 Sep 2016 14:53
Hello Nessism.I,m a new member,I've got a question for you maybe you can answer for me.I,m trying to get a 1980 750 ltd back out in the world and I've noticed every picture I see of one ,the clutch cover plate and ignition cover plate are two separate plates.Mine is one cover for both.My vin says kz750 G. Can you shed some light on that?Thanks
1980 Kawasaki 750 ltd G Twin
- GPzMOD750
Re: Re:RE: 1980 kz750 weak spark, first post
19 Sep 2016 15:07Send me your address.Nessism wrote: I don't think it matters if you leave the ignitor or take it out. If you are going to remove it and just throw it away please hit me up, I wouldn't mind getting my hands on a cheap backup.
19 Sep 2016 15:33OLJOCLARK wrote: Hello Nessism.I,m a new member,I've got a question for you maybe you can answer for me.I,m trying to get a 1980 750 ltd back out in the world and I've noticed every picture I see of one ,the clutch cover plate and ignition cover plate are two separate plates.Mine is one cover for both.My vin says kz750 G. Can you shed some light on that?Thanks
Have you checked the parts fishe? www.partzilla.com/parts/search/Kawasaki/...NE+COVERS/parts.html
- OLJOCLARK
19 Sep 2016 17:18
Thanks,I,m sure I,ll be referring back to that later.I should have looked at the Gallery sooner.There are lots of 750,s with the single cover plate.Looks like there were many options,handlebars,Fenders,and such.do you know what carberators you have? Assuming they are stock.
