I think I need a new voltage regulator.
Re: I think I need a new voltage regulator.
16 Jul 2016 16:38GPzMOD750 wrote:You are also using an aftermarket high output stator. My stator is obviously tired. Hopefully the one I'm getting isn't as tired. If worse comes to worst I'll get the super stator.Nessism wrote: Just checked my bike and it puts out 14.25 volts at 2000 rpm. If the SH parts are less efficient at low rpm it doesn't show.
As for good money after bad... I'm probably going to go back down this path with my shaftie so I'll already have most the options on hand. Once I get past that i'll pass on what I don't use.
I'm pretty sure Rick's stators are not high power. That's one of the reasons I bought it. At least they don't advertise as high power, and I think they would if they were.
- GPzMOD750
19 Jul 2016 18:18
It may not be high output compared to some stators (like Suzuki) but Ill bet they are higher output than standard Kawasaki's. That's probably why you're getting such good results with the SH775.
I got my "good" stator in today. The resistance readings ere 1.5 and 1.4 ohm range I mounted it and it was only getting 52 VAC at about 6500 rpm.
I'll wait for the MOSFET and see what that does for me.
19 Jul 2016 18:51
You're going through the school of hard knocks my friend. You bought a bad stator. I wish I had saved my old stators because they made about 13.7 volts DC which would be a big improvement from where you are at right now. The FH MOSFET R/R ain't gonna do anything to help the situation.
- loudhvx
19 Jul 2016 22:57 - 19 Jul 2016 22:58
I was posting on your ebay box-o-junk thread, and it occurred to me... you aren't using a Dyna S by chance are you?
There is a long history of Dyna S giving problems on single-phase Kz650's. Not all of them, just a percentage of them. Replacing the stators and reg/rec's wouldn't fix the problem.
It was assumed there was a batch of stators or rotors that made it out of the factory with slightly weaker output. This was fine until a Dyna S is installed. The Dyna S draws about twice the power as a stock points ignition, and much more if 3 ohm coils are used.
It still doesn't quite make sense, though, because one solution was to convert them to 3-phase using 750 parts, and that's what you have, presumably.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 19 Jul 2016 22:58 by loudhvx.
- GPzMOD750
20 Jul 2016 04:00 - 20 Jul 2016 04:03Nessism wrote: You're going through the school of hard knocks my friend. You bought a bad stator. I wish I had saved my old stators because they made about 13.7 volts DC which would be a big improvement from where you are at right now. The FH MOSFET R/R ain't gonna do anything to help the situation.
Apparently.
I contacted the seller and he said he would send everything he had to me...
I know he's just trying to provide good service but i don't know what to tell him.
I found a rebuilt Rick's stator, I'm wondering if I should get that one or maybe I should send one to Rick's for rebuild. I went to their web site but they don't have one listed for my bike. I currently have 2 extra to send them now.
loudhvx wrote: I was posting on your ebay box-o-junk thread, and it occurred to me... you aren't using a Dyna S by chance are you?
I do have a Dyna S w/3 ohm coils. Everything else is presumably stock except what has been discussed here.
I've had them on for quite awhile and I couldn't say whether there was any change when I put them on or not.
Last edit: 20 Jul 2016 04:03 by GPzMOD750.
20 Jul 2016 05:26
I'm pretty sure the 750R1 uses the same stator as the 750E. Partzilla says so anyway.
This Kawasaki 21003-1083 STATOR is used on these models and components:
1980 KZ750-E1 GENERATOR-REGULATOR ('80 KZY 50-E1)
1980 KZ750-E1 GENERATOR-REGULATOR ('81 -'82 KZ750-E2-E
1980 KZ750-H1 LTD GENERATOR-REGULATOR ('80 H1)
1980 KZ750-H1 LTD GENERATOR-REGULATOR ('81-'83 H2-H3-H4)
1981 KZ650-H1 CSR GENERATOR-REGULATOR ('81-'82 H1-H2)
1981 KZ650-H1 CSR GENERATOR-REGULATOR ('83 H3)
1981 KZ750-E2 GENERATOR-REGULATOR ('80 KZY 50-E1)
1981 KZ750-E2 GENERATOR-REGULATOR ('81 -'82 KZ750-E2-E
1981 KZ750-H2 LTD GENERATOR-REGULATOR ('80 H1)
1981 KZ750-H2 LTD GENERATOR-REGULATOR ('81-'83 H2-H3-H4)
1982 KZ650-H2 CSR GENERATOR-REGULATOR ('81-'82 H1-H2)
1982 KZ650-H2 CSR GENERATOR-REGULATOR ('83 H3)
1982 KZ750-E3 GENERATOR-REGULATOR ('80 KZY 50-E1)
1982 KZ750-E3 GENERATOR-REGULATOR ('81 -'82 KZ750-E2-E
1982 KZ750-H3 LTD GENERATOR-REGULATOR ('80 H1)
1982 KZ750-H3 LTD GENERATOR-REGULATOR ('81-'83 H2-H3-H4)
1982 KZ750-N1 Spectre GENERATOR-REGULATOR
1982 KZ750-R1 GPz GENERATOR-REGULATOR
1983 KZ650-H3 CSR GENERATOR-REGULATOR ('81-'82 H1-H2)
1983 KZ650-H3 CSR GENERATOR-REGULATOR ('83 H3)
1983 KZ750-F1 LTD Shaft GENERATOR-REGULATOR
1983 KZ750-H4 LTD GENERATOR-REGULATOR ('80 H1)
1983 KZ750-H4 LTD GENERATOR-REGULATOR ('81-'83 H2-H3-H4)
1983 KZ750-L3 GENERATOR-REGULATOR
1983 KZ750-N2 Spectre GENERATOR-REGULATOR
1983 ZX750-A1 GPz 750 GENERATOR-REGULATOR
1984 KZ700-A1 GENERATOR-REGULATOR
1984 ZX750-A2 GPz 750 GENERATOR-REGULATOR
1985 ZX750-A3 GPz 750 GENERATOR-REGULATOR
- GPzMOD750
Re: Re:RE: I think I need a new voltage regulator.
20 Jul 2016 06:44The Rick's part numbers are the same too. They don't show prices for rebuilding stators or "remanufactured" ones. They do have info about core returns. I sent then an email inquiring about rebuild charges.Nessism wrote: I'm pretty sure the 750R1 uses the same stator as the 750E. Partzilla says so anyway.
- missionkz
20 Jul 2016 10:31 - 20 Jul 2016 10:32Is the headlight on all the time in that model year? If yes, then disconnect it to check output voltage.GPzMOD750 wrote:Nessism wrote: You're going through the school of hard knocks my friend. You bought a bad stator. I wish I had saved my old stators because they made about 13.7 volts DC which would be a big improvement from where you are at right now. The FH MOSFET R/R ain't gonna do anything to help the situation.
Apparently.
Maybe if you don't drive at night much, you can put a 10amp toggle switch in somewhere to turn the headlight on or off.
Also, a two three ohm 50 watt power resistor only cost a couple three dollars and you can put it in series with your battery voltage to the coil's ...that will reduce the current draw a little bit too. Then you can check to see what the output voltage is to just see if your ignition system is drawing too much current for your charge system.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 20 Jul 2016 10:32 by missionkz.
- GPzMOD750
Re: Re:I think I need a new voltage regulator.
20 Jul 2016 10:51
I believe always on became mandatory in 81.
I've actually been messing with headlight wiring of late. I'll spare the details but the reserve system was causing major issues so I deleted it.
I'm actually planning on adding LED road lights and s second set of dual element running lights.
Besides asking for a ticket, reducing visibility with the drivers around here is a death wish.
- GPzMOD750
20 Jul 2016 15:24
MOSFET R/R is in AAAAAAAAAND.... nothin'.
Same numbers with either type of R/R. I guess this means my stator is dying. OK. I'll start looking for a stator I know will be good.
I'll put Rick's at the top of my list Nessism. My bike budget is getting seriously tight. You can have one of the SH775s for what I paid for it. $35 shipped. And tell someone to buy some of my take off parts.
20 Jul 2016 15:59
PM me your paypal address and I'll take one of those SH775's off your hands.
Regarding a stator, I'd look for a new one but cheaper than a Rick's if money is tight. This ElectroSport has a 1 year warranty. That seems reasonable for $81.50 shipped.
GPzMOD750 wrote: I'll put Rick's at the top of my list Nessism. My bike budget is getting seriously tight. You can have one of the SH775s for what I paid for it. $35 shipped. And tell someone to buy some of my take off parts.
The following user(s) said Thank You: GPzMOD750
- GPzMOD750
21 Jul 2016 04:51 - 21 Jul 2016 04:54
No eBay APP ID and/or Cert ID defined in Kunena configurationThanks,
I ordered it. Hopefully, I'll see some results.
I was looking at this one but red flags popped up on me. I sent Rick's an email asking about having mine rebuilt. The reply was that they no longer rebuild these stators since they offer new ones now and haven't since 2010. They don't offer warranty or returns and tell you to see the manufacturer...... And the a pic of a catalog pic doesn't instill confidence.
Last edit: 21 Jul 2016 04:54 by GPzMOD750.
