Dyna S ignition Question
Re: Dyna S ignition Question
15 May 2016 18:09
I'd get them from Z1e if I could. I like solid wires and non resistor caps.
15 May 2016 18:13Bozo wrote:The coils I have currently are standard GPZ1100 which measure 2.6ohm on primaryswest wrote: You can buy one pickup from Dyna. All you have are 1.5 OHM coils?
Throw a 1 ohm ballast resistor in series with the coil.
15 May 2016 18:20 - 15 May 2016 18:20swest wrote: I'd get them from Z1e if I could. I like solid wires and non resistor caps.
The metal-core Dyna plug wires come with non-resistor caps already built in, which I prefer along with standard B8ES non-R spark plugs, for zero resistance in the secondary loop, and which does introduce noise in radio reception (if that's a concern).
www.z1enterprises.com/search?q=dyna+plug+wires
Last edit: 15 May 2016 18:20 by Patton.
- Bozo
- Ride it like u stole it
15 May 2016 19:38Patton wrote:swest wrote: I'd get them from Z1e if I could. I like solid wires and non resistor caps.
Patton, we have very strict laws on radio/ TV reception (although you wouldn't think so with some bikes that go past) so we have to have resistive loads for suppression. I might stick with the caps and solid wire for now
- Bozo
15 May 2016 19:43Nessism, some times I feel like an idiot and don't see the obvious, you are correct I could use a ballast resistor. I just bit that bullet I was talking about and ordered a set of 3ohm Dyna coils. I just wish I had the brain switched ON before I did that.Nessism wrote:Bozo wrote:The coils I have currently are standard GPZ1100 which measure 2.6ohm on primaryswest wrote: You can buy one pickup from Dyna. All you have are 1.5 OHM coils?
15 May 2016 20:27Bozo wrote: . . . I might stick with the caps and solid wire for now
As likely already known, don't combine both resistor plug wires and resistor plug caps, as the combination creates too much resistance in the secondary loop, which results in a much weakened spark.
Only mentioned because of vaguely recalling some reference to carbon plug wires in an earlier post.
15 May 2016 20:39 - 15 May 2016 21:33Bozo wrote:Nessism, some times I feel like an idiot and don't see the obvious, you are correct I could use a ballast resistor. I just bit that bullet I was talking about and ordered a set of 3ohm Dyna coils. I just wish I had the brain switched ON before I did that.Nessism wrote:Bozo wrote:The coils I have currently are standard GPZ1100 which measure 2.6ohm on primaryswest wrote: You can buy one pickup from Dyna. All you have are 1.5 OHM coils?
Be proud of yourself for doing it the RIGHT way
But will confess to having lucked out when the squadron of black helicopters was hovering overhead and would have probably caught me red-handed with my zero resistance secondary loops, until they had to back off because all their sensitive electrics somehow went haywire. :woohoo: :lol: :lol:
Last edit: 15 May 2016 21:33 by Patton.
- Bozo
15 May 2016 21:20I did mention that my Z1R has carbon / resistive leads and the GPZ has resistive caps, I don't use both systems together.Patton wrote:Bozo wrote: . . . I might stick with the caps and solid wire for now
