- Thank you received: 3
Need new ignition coil for 1984 KZ440 D6
- BornAgainBiker
The bike is showing all the signs of weak spark: the spark looks red instead of light blue, the plugs run a bit on the sooty side, the engine has a slight miss especially at higher rpms or under load, plus power and fuel mileage are sub-par.
So, I was wondering if anyone could recommend a good replacement coil for my ride?
All the best, Jeff
1984 KZ440 D6
- bountyhunter
- Thank you received: 337
- Thank you received: 2749
- BornAgainBiker
All the best, Jeff
1984 KZ440 D6
- BornAgainBiker
All the best, Jeff
1984 KZ440 D6
- Thank you received: 2098
Question -- With the ignition switched ON and the engine NOT running, what is the measured voltage being received at the coil primary terminal as compared with the measured voltage between the battery posts?
The following illustration is an example of the several connections where voltage might be lost. (Just ignore the second coil in a dual coil system).
- Thank you received: 1656
- BornAgainBiker
Thanks Martin, I was considering A Dyna coil as a possibility.martin_csr wrote: Could he use a Dyna ignition coil? either 2.2 ohm or 3.0 ohm? or are they not available individually?
All the best, Jeff
1984 KZ440 D6
- loudhvx
- Thank you received: 1616
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- BornAgainBiker
Patton wrote: Perhaps the weak plug spark is resulting from loss of voltage between the battery and the coil.
Thanks for the great info Patton--I really appreciate it--what is acceptable voltage loss in the ignition system?
All the best, Jeff
1984 KZ440 D6
BornAgainBiker wrote: I see that there is a coil on ebay made by Caltric that fits my bike, but any reviews that I could find of their products were negative. Has anyone here had any experience with Caltric parts?
I bought a Caltric R/R. It failed in a week and almost ruined my alternator. Cheap CHINESE JUNK. :lol: That's a boat. :lol: :lol: :lol:
BornAgainBiker wrote: . . . what is acceptable voltage loss in the ignition system?
Would aim for no voltage loss or at least a very minimal voltage loss, because any loss is likely due to corrosion in the connections and/or switches between the battery and coil.
Could be helpful to verify the quality of spark produced when the existing coil is known to be receiving full voltage from a good fully charged battery.
Perhaps the existing coil is capable of producing fat blue plug sparks while the engine is being spun over via the electric starter (or kick starter if so equipped).
