KZ650 B Electrical/charging questions
- Forrest
- The Mad Duck
Re: KZ650 B Electrical/charging questions
20 Apr 2016 19:01twfields79 wrote: As far as the carbs go, I really seriously do not think they are clogged, I thoroughly cleaned and blew air through every passage, and blocked passages to reroute air flow to connecting passages, I dipped every part and let sit in Chem-dip and put rebuild kits in, and installed an inline filter in my fuel line.....
Late to the Party here! Glad you are narrowing your search.
20 Apr 2016 19:05twfields79 wrote: Well I'm about half positive someone put superglue or something similar being it was around the edges of the switch, and I seemed to have broke one of the rings on the c clip.....
If mine breaks again I'll buy a new one at z1partsinc.
z1parts.net/z1-900-kz900-left-side-control-switch/
- twfields79
20 Apr 2016 19:17
Nice! I was wondering if those controls would work!! The plastic piece under the run/off switch is broke in 3 different places..... It's either a new unit or buy a used one and rob the part.....
1978 KZ650 B2
20 Apr 2016 19:29
Mine was too. I put it together with the glue and coated the back with JB getting under the wires. 40 year old part. I'll buy new next time. I bought the R/H side but am keeping the stock one. Worth $$. Period correct.
Steve.
Steve.
- twfields79
20 Apr 2016 19:29
Will those controls work on my 650? I Will need the right hand side
1978 KZ650 B2
20 Apr 2016 19:37
I think they will. Here's another place. You will have to figure out the wiring but at least you'll have a headlight switch if you don't have one.
Check Z1E too.
www.diablocycle.com/Kawasaki-Z1-KZ900-Ha...witch-Left-Side.html
www.diablocycle.com/Kawasaki-Z1-KZ900-Ha...itch-Right-Side.html
Check Z1E too.
- twfields79
22 Apr 2016 11:12
I'm at a stand still now, my new controls should be here Tuesday. I may be off on what the actual problem is with my bike, but I know 9v at the coils is not good, so once it's fixed I can then move forward if it does not solve my problem..... Thanks everyone for the help, I will keep you posted
1978 KZ650 B2
- twfields79
26 Apr 2016 11:01
Does anyone have a wire diagram for a kz900. I'm trying to figure out where to connect these wires on this new control switch
1978 KZ650 B2
