KZ650 B Electrical/charging questions
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: KZ650 B Electrical/charging questions
20 Apr 2016 17:39
#722066
Get some contact cleaner and spray inside it while turning it off and on, disconnected of course. I've tasken them apart but unless you know what you're doing, you can mung it up.
  • twfields79
  • twfields79's Avatar Topic Author
20 Apr 2016 17:46
#722069
Good deal, I'll give it a shot!
1978 KZ650 B2
  • twfields79
20 Apr 2016 17:47
#722070
As far as the hand controls, just take them apart and clean?
1978 KZ650 B2
  • Forrest
  • Forrest's Avatar
  • The Mad Duck
20 Apr 2016 17:55
#722073
Focus here has been electrical, right? Just playing carbuerator advocate, Have you considered your main jets(one or more) are still blocked? The bike behavior you are describing sure seems carbuerator related as in: bike idles then bogs on giving throttle. Just my $0.02. :whistle:
p.s. I recently chased an electrical gremlin on my 2011 C-14 and turned out it was something as simple as the ground connection from my PCV. Bike would just die like it was out of fuel. The Power Commander ground was loose and during a ride would vibrate and cause a break in the connection. :pinch:
  • SWest
  • SWest's Avatar
  • 10 22 2014
20 Apr 2016 18:11
#722077
twfields79 wrote: As far as the hand controls, just take them apart and clean?
Controls are easy. They're screwed together. I cleaned mine and used lithium grease. That was three years ago. Still working today. I need a new ignition switch, it's old and the key is sloppy.
  • twfields79
20 Apr 2016 18:25
#722081
The focus is electrical at the moment, because I'm only getting 9.78v at the coils. I cleaned ignition switch and am now getting 11.48 volts out, but 12.29v in, which is better, but I took apart the controls and am getting the same 11.48 in, but 9.78 out, I sprayed contact cleaner inside, but my run off switch seems sloppy, is there a way to get it out to clean/"adjust" it?
1978 KZ650 B2
  • SWest
  • SWest's Avatar
  • 10 22 2014
20 Apr 2016 18:27 - 20 Apr 2016 18:29
#722087
It has a cir clip and is spring loaded. Careful. Mine was sloppy too. The board was broken. I used crazy glue and JB Weld around the wires. It's still working too. Had it bypassed before.
Last edit: 20 Apr 2016 18:29 by SWest. Reason: add text
  • twfields79
20 Apr 2016 18:28
#722089
As far as the carbs go, I really seriously do not think they are clogged, I thoroughly cleaned and blew air through every passage, and blocked passages to reroute air flow to connecting passages, I dipped every part and let sit in Chem-dip and put rebuild kits in, and installed an inline filter in my fuel line.....
1978 KZ650 B2
  • twfields79
20 Apr 2016 18:29 - 20 Apr 2016 18:31
#722090
Where is the clip? Is it the two small ones around the screw holes underneath?
1978 KZ650 B2
Last edit: 20 Apr 2016 18:31 by twfields79. Reason: Misspell
  • SWest
  • SWest's Avatar
  • 10 22 2014
20 Apr 2016 18:34
#722092
The clip is visible in the top portion. The contacts are in the turret where the switch lever sits. Tricky to get to.
  • twfields79
20 Apr 2016 18:36
#722093
Ok thanks I'll go check it out!!
1978 KZ650 B2
  • twfields79
20 Apr 2016 18:47
#722096
Well I'm about half positive someone put superglue or something similar being it was around the edges of the switch, and I seemed to have broke one of the rings on the c clip.....
1978 KZ650 B2
