76-80 KZ1000 wiring harness compatibility?
  • Chico 80 1000-E2
  • Chico 80 1000-E2's Avatar Topic Author
04 Jan 2016 15:00
#705615
Hi guys, new member here!
Been going through a partial electrical fiasco on my 1980 KZ1000-E2 (shaft) harness: PN 26001-1079 main and -1069 rear. I was unable to find these specific items online; however, I found a new one that fits a 77-78 KZ1000 A1, A2, A2A from Z1 Parts Inc. I was wondering if they were compatible? Or close enough that it would require minors modifications. Can anyone point me in the right direction? I emailed Z1 Parts, but I would like to have multiple points of views.
Partzilla....obsolete.
thanks again!
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 76-80 KZ1000 wiring harness compatibility?
04 Jan 2016 15:02
#705618
Get a guarantee.
  • Tyrell Corp
  • Tyrell Corp's Avatar
04 Jan 2016 15:18 - 04 Jan 2016 15:22
#705627
You could look at the wiring diagrams, and compare - noting the the multiblock connectors etc. If just the connector placement within the block connector confuguration is different this is quite easy to sort. Look at the ignition switch, charging and ignition components and see if they are the same.
Really if you are going to be doing anything more than unpicking a few block connectors you would be better getting the right part. I transferred a GPZ11B loom on to my ELR and it was a lot more work than anticipated. The shaft drives seem less sought after and may be easier to find a breaker.
Alternatively there are companies that will copy your loom with new wire in the correct gauge and colour code with genuine Hitacjhi mini-block connectors. About £175 UK I'm told.
Don't underestimate the sub looms (switchgear, alternator, tail, clocks....generally the ones that cause the trouble that won't be included in the main harness. A good auto electrician could sort this for you, testing and replacing where necessary..
Last edit: 04 Jan 2016 15:22 by Tyrell Corp.
  • Chico 80 1000-E2
05 Jan 2016 04:04
#705667
Thanks for your help guys. While searching some more, found several US companies that have custom made harnesses. Sparcko Moto sells a universal, trimmed down, basic harness and a bike-specific harness. Waiting for their response regarding application; however, I think this might just work for me. For sure Steve I will get a guarantee!
Thanks again. We'll keep y'all posted on the progress.
  • floivanus
  • floivanus's Avatar
05 Jan 2016 06:22
#705690
77-78 have a piece meal design, there's a main harness a junction block etc. 79-80 are a solid one piece junction blockless design
Past; 78 kz1000, 83 kz550
Andrew
  • Tyrell Corp
05 Jan 2016 14:37
#705732
...sells a universal, trimmed down, basic harness and a bike-specific harness.
Don't.
Do you have a harness already? it can be repaired / copied.
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Jan 2016 14:41
#705733
My thoughts exactly. Fix yours if you can.
